Transmission Fluid change ...
Old Dec 4, 2010 | 06:52 PM
alloro's Avatar
alloro
Originally Posted by efair
Did you receive it?
Nope, I only got your first message saying that you were going to send the attachment later at night. I never got a second email with the attachment.
Old Dec 7, 2010 | 08:18 AM
efair's Avatar
efair
I emailed it to you again, any luck this time?
Old Dec 7, 2010 | 09:32 AM
alloro's Avatar
alloro
Yes, I just found it this morning. The biggest issue that I see is that bullets were used and those don't transfer over at all.
Anyway, it's all set and I sent it back to you so that you can post it.
Old Dec 7, 2010 | 02:46 PM
efair's Avatar
efair
alloro, thank you for the quick tutorial on formatting, I've edited my original posting and it looks great!
Old Dec 7, 2010 | 06:20 PM
alloro's Avatar
alloro
If you do say so yourself.
Yes, it does look much better now!
Old Oct 6, 2014 | 10:57 AM
DND58's Avatar
DND58
Bringing this back from the dead. Anybody else use this procedure? Anything to add? Filter number?...
Old Oct 6, 2014 | 07:35 PM
r2millers's Avatar
r2millers
Motorcraft FT 113 filter. Long neck stemmed filter if 4r100 with the 20 bolt pattern.
Clean magnet and drain pan of gunk buildup. Reuse the same, original OEM gasket, not replacement cork.
Old Oct 7, 2014 | 05:11 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I paid the dealer $159.00 for the fluid exchange and he called me when it was done. And Ford's service warranty is two years and unlimited miles.
I'd imagine the cost of the ATF alone is about half the cost of paying a shop to do the exchange.
Old Oct 7, 2014 | 09:57 AM
r2millers's Avatar
r2millers
I just wonder what that Service Warranty includes and how does it apply?
When is it determined if it needs to be changed again? 35k or so as the manual suggests?
Is it only replacement "service" if changed within 2 years, not the ATF?
I agree that the ATF will run around 60 bucks with 100 in labor. If they'll do it every 35k for about 60 bucks within 2 yrs, then not a bad deal.
Old Oct 7, 2014 | 04:35 PM
tseekins's Avatar
tseekins
The service interval on my 2004 Expy is 30K, the 2005 jumped to 60K so I have it done every 45K knowing that nothing has changed with the equipment in one year.
Current transmissions are running LV fluid which is a lifetime fluid or 150K, which ever comes first. So realistically, $160.00 for a trans service every 100K -150 isn't a bad deal.
jeffreyt
419
Apr 12, 2026 05:56 PM
creator
Oct 11, 2016 10:28 AM
coolfeet
Mar 9, 2016 06:48 AM
Encho
Mar 3, 2016 02:45 PM
HiSPL
Jul 17, 2009 03:25 PM
