Head Bolts vs Grade 8's
Old Nov 29, 2010 | 12:22 PM
2ktrott's Avatar
2ktrott
I am replaceing the rusted out heads on my 460 F350. Do I need to use heads bolts or can I replace the exterior ones with Grade 8 bolts instead. Since I only need the exterior ones, can't see spending the $$ for a new set if I don't need to.
Old Nov 29, 2010 | 12:32 PM
L. Ward's Avatar
L. Ward
If you need to replace some of them, you need to replace all of them, and no I would not use G8 hardware store bolts.
Old Nov 29, 2010 | 12:36 PM
2ktrott's Avatar
2ktrott
That's what I was afraid of. I will order a new set today. Thanks
Old Nov 29, 2010 | 01:34 PM
bubblegum's Avatar
bubblegum
What about stronger bolts (Grade-10?) from a specialized place like Fastenal or McMaster-Carr?
Old Nov 29, 2010 | 05:23 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Problem .. well use to be was Head bolts were a odd length. G10 might work but you might have a hard time finding that size in the length you need. Longer one just don't fit. Fastenal is a LOT of import stuff. McMaster - Carr is a great place but they take to much of my money every year! LOL I think you woudl still be better off just getting a set and know there the right grade and size to do the job.
Just looked Only thing McMaster has in the Grade 10.9 with the flange head is metric. That kind of sucks! I need to complain to them! LOL
Old Nov 29, 2010 | 05:37 PM
danr1's Avatar
danr1
Yea I agree and while I'm all for saving a few bucks/short cuts whenever possible, and even though they might work just fine I wouldn't use the grade 8's, replace all the bolts with "stock" head bolts.
You don't want to have to pull the head/s again because the bolts exact makeup wasn't right, might not withstand the temperature swings long term for example.
Old Nov 29, 2010 | 06:32 PM
EPNCSU2006's Avatar
EPNCSU2006
Class 10.9 is a metric specification, roughly equivalent in strength to SAE grade 8. That's why you can't find standard size fasteners with a class 10.9 strength rating.
As for the head bolts, I would try ARP if you don't want factory replacements. You can probably find replacements at say NAPA or CarQuest. I think if you're going to replace any of them that you should go ahead and replace them all.
Old Nov 29, 2010 | 06:49 PM
91chevywt's Avatar
91chevywt
I always get a new set of head bolts for a major overhaul or a head gasket job. Not a place to go cheap. If you want better than stock bolts, or would rather have studs then ARP should make something for you
Old Nov 29, 2010 | 06:51 PM
bubblegum's Avatar
bubblegum
It was just a random idea, nothing more, but thanks for the explanation of why it was a bad idea
I have seen metric bolts that have 12.9 written on their head, would those be roughly equivalent in strength to Grade-10 standard bolts? (this is just for my own general knowledge)
Old Nov 29, 2010 | 06:59 PM
L. Ward's Avatar
L. Ward
The first number is the tensile strength or the pressure required to actually break the bolt.. This number can be between 4 and 14 with 14 being the toughest. To convert that number into something useful, take the first number on the head, multiply it by 100 (this give you tensile strength in N/mm2), then multiply it by 145 to get you the PSI that the bolt is rated at. A metric bolt with a 12 for the first digit, for example, would have a tensile strength of 174,000 PSI (12x100=1,200N/mm2 x 145=174,000psi).
Bolt Grade Markings and Strength Chart
<table style="width: 447pt; margin-left: 3.75pt;" border="1" cellpadding="0" cellspacing="0" width="596"><tbody><tr style="height: 24pt;"> <td rowspan="2" style="width: 16%; height: 24pt; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Head Markings
</td> <td rowspan="2" style="width: 13%; height: 24pt; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Grade or Class
</td> <td rowspan="2" style="width: 15%; height: 24pt; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Material
Nominal Size Range
(Inches)
</td> <td colspan="3" style="height: 24pt; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Mechanical Properties
</td> </tr> <tr> <td style="width: 11%; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Proof Load (psi)
</td> <td style="width: 13%; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Minimum Yield Strength (psi)
Minimum Tensile Strength (psi)
</td> </tr> <tr> <td colspan="7" style="padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
American Bolts
</td> </tr> <tr style="height: 44.25pt;"> <td rowspan="2" style="padding: 0.25pt; height: 44.25pt;" valign="top">
No Markings
</td> <td rowspan="2" style="padding: 0.25pt; height: 44.25pt;" valign="top">
Grade 2
Low or Medium Carbon Steel
</td> <td style="padding: 0.25pt; height: 44.25pt;" valign="top">
1/4 thru 3/4
55,000
57,000
74,000
</td> </tr> <tr style="height: 45pt;"> <td style="padding: 0.25pt; height: 45pt;" valign="top">
Over 3/4 thru 1-1/2
</td> <td style="padding: 0.25pt; height: 45pt;" valign="top">
33,000
36,000
60,000
</td> </tr> <tr style="height: 45pt;"> <td rowspan="2" style="padding: 0.25pt; height: 45pt;" valign="top">
3 Radial Lines
</td> <td rowspan="2" style="padding: 0.25pt; height: 45pt;" valign="top">
Grade 5
Medium Carbon Steel, Quenched and Tempered
1/4 thru 1
85,000
92,000
120,000
Over 1 thru 1-1/2
74,000
81,000
105,000
</td> </tr> <tr style="height: 1.25in;"> <td style="padding: 0.25pt; height: 1.25in;" valign="top">
6 Radial Lines
</td> <td style="padding: 0.25pt; height: 1.25in;" valign="top">
Grade 8
Medium Carbon Alloy Steel, Quenched and Tempered
1/4 thru 1-1/2
120,000
130,000
150,000
</td> </tr> <tr style="height: 44.25pt;"> <td rowspan="3" style="padding: 0.25pt; height: 44.25pt;" valign="top">
Stainless markings vary. Most stainless is non-magnetic
</td> <td rowspan="3" style="padding: 0.25pt; height: 44.25pt;" valign="top">
18-8 Stainless
Steel alloy with 17-19% Chromium and 8-13% Nickel
1/4 thru 5/8
40,000 Min. 80,000 – 90,000 Typical
100,000 – 125,000 Typical
</td> </tr> <tr style="height: 24pt;"> <td style="padding: 0.25pt; height: 24pt;" valign="top">
3/4 thru 1
</td> <td style="padding: 0.25pt; height: 24pt;" valign="top">
</td> <td rowspan="2" style="padding: 0.25pt; height: 24pt;" valign="top">
40,000 Min. 45,000 – 70,000 Typical
100,000 Typical
</td> </tr> <tr style="height: 30pt;"> <td style="padding: 0.25pt; height: 30pt;" valign="top">
Above 1
</td> <td style="padding: 0.25pt; height: 30pt;" valign="top">
</td> </tr> <tr style="height: 19.5pt;"> <td colspan="7" style="height: 19.5pt; padding: 0.25pt; background: none repeat scroll 0% 0% rgb(217, 217, 217);">
Metric Bolts
8.8
Class 8.8
All Sizes thru 1-1/2
85,000
92,000
120,000
10.9
Class 10.9
120,000
130,000
150,000
A-2 Stainless
1/4 thru 5/8
3/4 thru 1
100,000 Typical
Above 1
</td> </tr> <tr style="height: 0.5in;"> <td colspan="7" style="padding: 0.25pt; height: 0.5in;" valign="top"> Tensile Strength: The maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing.
Yield Strength: The maximum load at which a material exhibits a specific permanent deformation
Proof Load: An axial tensile load which the product must withstand without evidence of any permanent set.
</td></tr></tbody></table>
Old Sep 10, 2013 | 09:07 AM
warren561's Avatar
warren561
Sorry to dig up such an old thread. But this chart is so handy!
Old Sep 11, 2013 | 10:55 PM
quaddriver's Avatar
quaddriver
unless you are using ttys (torque to yeild bolts) which you aint, you can re-use a head bolt set from about any street 460.
that being said, dont pop off the bottoms and not the top, you will blow the head gasket shortly thereafter....do it right or not at all (also head bolts tend to be shouldered to minimize movement
mr lucky
Sep 5, 2022 10:35 AM
Jeff Metz Jr.
Apr 27, 2017 04:05 PM
Jimmiej08
Feb 15, 2017 12:38 PM
frdf250
May 9, 2016 10:34 AM
countryartistjk
Jan 14, 2012 12:09 PM
