re: '92 ford exploder question...
if any of you recognize the name, i am the guy who's engine got swamped and i sucked water into my engine....
(and i realize i did not post this whole story on this message board, but i am lazy...)
i began my task of removing the plugs (surprisingly easy considering that the pasenger side is buried).
but considering this... i had no problems removing the spark plugs... but i can't exactly put my thumb on where the oil pan drainage plug is.
what i thought is the oil pan plug is very tight and wont budge... so therefore i am thinking it might be the transmission drain plug. I have checked the library's reference section for the Chilton guides and they really don't get into details about the pan.
i had the oil changed 3 weeks ago (along with a 630 dollar brake overhaul... my luck that my engine might be toasted... )
anyways... would anyone be kind enough to show a picture or a clear diagram where this plug might be and where exactly?
the plug i am playing with (is stripped now) is located behind the front axle (upside down) in clear sight...
i have read and heard the oil plug is kinda in ****ty area where it runs all over the place... so i am thinking this can't be it... thanks all
rob miller
