Which front hub can I use?
Old Nov 29, 2010 | 09:50 AM
erichy's Avatar
erichy
Hey guys I have a 1999.5 F250 and I'm going to put new front wheel bearings in this weekend. I have rear wheel ABS only so I'm looking at the hubs without ABS and they are more expensive which makes no sense to me. Can I use the ABS hubs and cut the wire? It would save some money and I would have the port to pump grease in there. Is it the exact same hub just one has the wire and one doesn't? Thanks in advance. Eric
Old Nov 29, 2010 | 10:39 AM
woodnthings's Avatar
woodnthings
Usually it is the other way around! But yes, you can use those hubs!
Old Nov 29, 2010 | 11:38 AM
just another truck's Avatar
just another truck
and there is no need to cut the wire, just tie it up..
Old Nov 29, 2010 | 12:00 PM
spunks00's Avatar
spunks00
yeah cut the wire thats what i did
Old Nov 29, 2010 | 01:51 PM
erichy's Avatar
erichy
Awesome thanks guys.
Old Nov 29, 2010 | 09:23 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
which bearing units are you going with?
Old Nov 29, 2010 | 10:15 PM
erichy's Avatar
erichy
The cheapie on eBay.
Old Nov 29, 2010 | 10:27 PM
big poppa's Avatar
big poppa
Just make sure if yours are the coarse threads or the fine thread hubs, theres two kinds. I've never ordered hubs but to be safe, take a look, unless you know already.
Old Nov 29, 2010 | 10:32 PM
SpringerPop's Avatar
SpringerPop
Don't cut the wire, just fab some plugs and save the ABS sensor to give it to one of the brothers who might need it one day.
Pop
Old Nov 29, 2010 | 11:47 PM
homesteader's Avatar
homesteader
I got my hubs from Napa it was national with 3yr warranty . I would stay away from the cheapy ones just my opinion .
Old Nov 30, 2010 | 09:22 AM
woodnthings
Most say those only last a year or two. Better off to buy the Timken ones IMO if you plan on keeping it!
Old Nov 30, 2010 | 10:03 AM
erichy's Avatar
erichy
I agree the cheap ones are not the best route but money is tight and I only put 8000 per year on the truck. The next set will be timken. I appreciate your input though. Do you guys know if the guy fabing the grease ports for the abs port is selling them yet?
Old Nov 30, 2010 | 11:09 AM
woodnthings
I don't think he was selling them per say. The drawing is available and you should be able to make one up, or have one made locally. I know I built one from the drawing and it took less than a half hour on my mini-lathe. If you are wanting it to be a plug, you can plug it with a rubber plug or something from a hardware store. Just make sure it has a positive engagement, so it won't fall out.
