Need ans
Old Nov 29, 2010 | 05:33 AM
Stacey Johnson's Avatar
Stacey Johnson
Need ans
I have a 05 f150 supercrew 4x4 kingranch 6 months ago I put a edge evalution program on and a coldair intake already had flowmaster ex I started getting 19 to 20 mpg onthe hwy last week I put straight pipes on then went on a 10 hr trip pulling a load didn't get but 10 mpg on trip got home come to work in it it's a 9 hr ride to work didn't get but 16 mpg with cruise set on 75 has anybody got any idea what happend
Old Nov 29, 2010 | 05:47 AM
shorebird's Avatar
shorebird
Welcome to FTE.
Loss of back-pressure would be the source of the MPG drop I think.
Old Nov 29, 2010 | 06:15 AM
shotgunz's Avatar
shotgunz
You're using a tuner that's designed for stock intakes and exhausts. If you think I'm FOS, call Edge and ask them.
Get the Edge converted to a Gryphon and get custom tunes for the intake and exhaust.
Power Hungry Performance - Feed your hunger for POWER!
Did you set the Edge to Level 2 when you towed?
Don't forget the winter blend gas is here too.
Old Nov 29, 2010 | 06:20 AM
Stacey Johnson
Loss of back pressure what is that
Old Nov 29, 2010 | 06:24 AM
shotgunz's Avatar
shotgunz
A term (mostly a myth) that describes the effect of changing to a free-flowing exhaust (no cats, larger pipes, etc.).
If you get a custom tune you won't have to worry about it.
Old Nov 29, 2010 | 06:44 AM
Stacey Johnson
Well I had flowmasters on it and was getting good mpg I think I'll putt them back on or maybe go to banks
Old Nov 29, 2010 | 06:55 AM
shotgunz's Avatar
shotgunz
If you don't want to listen to sound advice, why bother to ask questions?
Old Nov 29, 2010 | 06:59 AM
Stacey Johnson
So u think I need to go back to stock is the coldair intake helping or no
Old Nov 29, 2010 | 09:19 AM
shotgunz's Avatar
shotgunz
You need to go back to the stock intake until you get custom tunes for the intake.
A cat back exhaust doesn't need custom tunes. If your definition of straight pipes is no cats, you definitely need custom tunes. I'm surprised your CEL didn't light (O2 sensor).
You never answered my question about towing nor did you acknowledge the normal MPG drop for winter.
9 reasons why your winter fuel economy bites! - MetroMPG.com
Lastly, if you're relying on the lie-o-meter (truck or Edge), your REAL MPG is probably a lot different. It would be weird if your calculated MPG was higher than the lie-o-meter, but not unheard of.
Old Nov 29, 2010 | 02:56 PM
Stacey Johnson
No I didn't have it in towing
Old Nov 29, 2010 | 03:25 PM
MCDavis's Avatar
MCDavis
Just a little word of advice Stacey...Shotgunz is trying to help you out here, but you are somehow avoiding the majority of his questions which could potentially help ya out.
Slow down, read his posts, and assess his questions.
Welcome to FTE.
Old Nov 29, 2010 | 04:46 PM
Stacey Johnson
I think I told yah wrong I don't have true straight pipes the cadilac converters are still on is that any help
Old Nov 29, 2010 | 04:50 PM
shotgunz's Avatar
shotgunz
Okay Stacey - let's start from the beginning.
1. Have you read the owner's manual for the Edge?
1.a. Are you sure your GR and TS are correct?
1.b. Do you know how to program the PCM from stock to a different level?
1.c. Do you now realize you shouldn't tow or haul anything over 2000 lbs (approximately) on level 3? In fact with your model year, I wouldn't tow anything unless I was on level 2.
1.d. Do you know that there are octane requirements? Do you meet them?
1.e. Have you confirmed your odometer and speedometer are accurate (or real close)? See 1.a (above).
1.f. Have you changed ANY of the user adjustable parameters on the Edge?
2. Who installed the under-the-hood intake bling? What manufacturer? Are all the connections tight?
3. Who installed the exhaust? Any leaks?
4. Is the truck's maintenance up-to-date (per the maintenance guide)?
5. Any codes (DTCs)? (The Edge can read them.)
Old Nov 29, 2010 | 05:03 PM
Stacey Johnson
Ok i put the prog in my self and yes I will put it in towing next time all I have changed is the shift fermness and I put the intake on myself everthing seems like it's still tight I don't have any messages on my truck but a abs message do u think that has anything to do with it I'm not trying to be hard headed I don't understand everthing your telling me is there anyway I can reset my computer completly and start over
Old Nov 29, 2010 | 05:28 PM
shotgunz's Avatar
shotgunz
Using the Edge Put the PCM back to stock. This will be described in the manual.
Put the stock intake back on. Go to PHP's website and read about converting it to a Gryphon with custom tunes for your intake. Make sure you tell them you're running without a muffler. They'll need your gear ratio and tire size.
You'll have to send the Edge to PHP. They'll convert it to a Gryphon and send it back with custom tunes (I recommend 87 performance, 87 towing, and keep the canned 93 performance - unless you want to run 93 octane, then you also need a 93 performance). When you get it back you can install the intake and Gryphon.
It's possible your odometer is wrong (which will affect your MPG) because you have the wrong gear ratio and tire size. Again, this is explained in the Edge manual.
Do not rely on the lie-o-meters (Edge and truck) to measure your MPG. Hand calculate each tank and keep a running average. Fuelly.com is a great web-site to track and compare your MPG.
