EBPV sensor cleaning question
Old Dec 17, 2010 | 01:12 AM
stangclassic66's Avatar
stangclassic66
Did you see a mileage improvement?
Old Dec 17, 2010 | 03:47 AM
twags6's Avatar
twags6
Another trick to clean out the tube is shove a piece of weed whacker string through it (the kind that has ridges in it is best) and attach that to a drill. Spray some brake cleaner in the tube and run the drill both directions. It really cleans the soot out well.
IIRC, the dummy plug that gets installed is for the EBPV actuator not the EBPS. The EBPV is on the turbo and the dummy plug replaces the actuator for that valve so it doesn't set a code.
Old Dec 17, 2010 | 04:25 AM
locknload223's Avatar
locknload223
I won't be able to tell for a while, this doesn't get driven much. It did turn off my CEL though.
I need to unplug my EBPV actuator, it's closing constantly in this weather and is a pain in the butt. I should have done it when I had the spider out. I'll stop by Radio Shack on the way home and pick up that resistor, I don't even want soft codes.
Old Dec 19, 2010 | 06:12 PM
Skip1970's Avatar
Skip1970
so whats the story? howd it work out?
im thinking about checking if mines packed, my mpg sux i got 185k and the previous owner obviously didnt give a damn. so i imaging its packed up too..
also does anyone know how to do a cyl contribution test with ae? i got my ae but dont know how to test.
Old Dec 19, 2010 | 08:05 PM
Franko72's Avatar
Franko72
Molon Labe
I unplugged mine a few thousand miles ago and haven't noticed any difference in milage. no CEL either ?
Old Dec 19, 2010 | 08:21 PM
tdpower's Avatar
tdpower
You rebel you......I did the same. It will just set a soft code and no CEL..I'm thinking of putting a new tube on my list of to do's. I already got the sensor and I was to much of a cheap **** to replace. On Bob's site he says DP tuner says it is good to have .
Old Dec 19, 2010 | 08:26 PM
Franko72's Avatar
Franko72
Molon Labe
I guess I'll add that to my list....Thanks Grant.
My ICP is first, i'm getting tired of the fluctuating idle and cruise.....my work is never done.
Old Dec 19, 2010 | 08:55 PM
tdpower's Avatar
tdpower
Hopefully, your FTE brothers down in Houston can help you figure it out. You really need something like AE.
Old Dec 20, 2010 | 04:35 AM
locknload223
Damn, you're up early like me. I won't know if there's a mileage increase until my next trip, whenever that is. It shut off my CEL so the ECU is getting proper signal know. All should be back to normal.
I just ordered my AE Saturday so post up when you figure it out.
Old Dec 20, 2010 | 04:50 AM
Skip1970's Avatar
Skip1970
i never get a cel... did yours idle up to 900 or so rpm also when it was warmed up randomly?
Old Dec 20, 2010 | 04:52 AM
locknload223
No, it never ran any different than normal. The only way I knew was pulling the code after seeing the CEL.
Old Dec 20, 2010 | 04:58 AM
Skip1970's Avatar
Skip1970
Originally Posted by Trouble1263
Dude!!
Shop some more on ebay. Use the Ford part #'s..also try motorcraft #'s..I got my sensor for $23.00 shipped..I used brake cleaner on my tube and it worked well, used a #14 solid wire to ream out the tube, took some time, but a lot cheaper in time than a new tube
whats the part number?
Old Mar 11, 2011 | 02:27 PM
  #28
Studawg's Avatar
Studawg
Thread Ender
thats what I want to know
Old Mar 11, 2011 | 02:43 PM
  #29
Brother Les's Avatar
Brother Les
Replacement O-rings for Ford Diesel Engines
www.partsguyed.com
  #30
Studawg's Avatar
Studawg
Thread Ender
I think I found the part number: 4C3Z9J460A
That links to one on eBay for $102!!!! I am going to look further. Or else just clean the one I have.
