04 Excursion Headlight not working properly
Old Nov 28, 2010 | 02:51 PM
steven-04 Excursion's Avatar
steven-04 Excursion
I bought an 04 Excursion 6.0L diesel a week ago. Was using it this weekend and had the headlights stop working three times, neither high or low beam working in either head light when this happens. First time I drove home on the fog lights and checked all the fuses for the lights, made sure they were tight and when I turned them on again they worked. Second time the headlights came on when I pulled it out for the fog lights. Third time I had to stop at a store on the way home and when I put it in park they magically came on. All other lights work and not other issues I can tell. I popped the switch and wiring is tight. I checked the headlight connections today when I got home from work and they are tight but lights are again not working. I figure it has to be something loose? Thoughts?
Old Nov 28, 2010 | 04:54 PM
Stewart_H's Avatar
Stewart_H
I suck at anything electrical, but I'm wondering if it's a grounding issue?
Either way, here's a bump for ya.
Stewart
Old Nov 29, 2010 | 04:46 AM
steven-04 Excursion
Possible though curious that all other lights work when just the headlights do not. And I am not even sure where to start looking for a loose ground in that sea of wiring. And when they come they don’t flicker and both hi and lo beam work. Maybe it is the switch though that wouldn't explain lights coming on when I put it in park.
Fastback460
Jan 2, 2015 12:41 PM
hasteranger
Nov 25, 2014 10:57 PM
wrxin
Sep 15, 2014 03:09 PM
mthorlakson
2004 - 2008 F150
Mar 22, 2013 02:43 PM
KM04Excursion
Oct 28, 2011 01:15 PM
