Gear ratio help
Old Mar 1, 2003 | 12:38 PM
erikl85's Avatar
erikl85
Gear ratio help
On my 77 460, what would the gearing ratio be? I have a c-6 and it is in a f-250. What would be the best gearing for speed? And also what would be the compromise gearing, a little for speed and a little for normal use? Thanks.
Old Mar 1, 2003 | 01:13 PM
Mil1ion's Avatar
Mil1ion
Gear ratio help
This question is not 460 relevant,
Moving to truck forum.
Old Mar 1, 2003 | 01:50 PM
wick246's Avatar
wick246
Gear ratio help
Many people here can decode what your current (if it is stock) gear ratio is from the codes on the door jamb sticker or the tag bolted to the cover on your axle. They will also need your tire size to make gearing suggestions.
