Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Garage Heating and Cooling
Old Nov 28, 2010 | 06:00 AM
SuperDoodieDutyDude's Avatar
SuperDoodieDutyDude
Looking for some tips on what may be the best option for climate controlling a garage. Area is 38' x 24' with 10 foot ceilings. It's well insulated, has 2 windows where a window unit could be installed, which is what I would prefer, I'm just not sure it would be enough. If it isn't going to be enough I would hate to waste the money so I would like to hear from anyone that has any helpful info. In the winters it can get down to the 20s but not much if any colder and the summers can be consistently in the high 90s to low 100s.
Old Nov 29, 2010 | 05:18 AM
wiseguy's Avatar
wiseguy
I've got a 42'x60' with 14' eaves and 21' at the peak. I use a propane-fueled Munchkin boiler with radiant in-floor heat to heat it. Cooling it is done with two industrial ceiling fans. The heat isn't too much of a problem, because of the high ceiling. If your slab is already poured, the radiant in-floor heat is out, but you could check into the radiant heaters that mount to the ceiling.
Old Nov 30, 2010 | 06:59 AM
PupnDuck's Avatar
PupnDuck
Based on my calculations, you'd need at least a 25,000 BTu unit to cool that area and that's if:
You keep the door closed all the time.
You don't park a hot truck in the garage.
Otherwise, you should double that unit size. Fans and cold beverages might be a better and cheaper idea.
Old Dec 2, 2010 | 02:33 PM
DAVE67FD's Avatar
DAVE67FD
As far as heat goes i have been researching my options for awhile for my 28x38 and have decided on the Mr. Heater Propane Garage heater. They also make a smaller 45k BTU as well as a natural gas unit.
You could go with an electric 4-5k wall unit but if you spend a fair amount of time in the garage it will get costly even though the units are relatively inexpensive.
The vent free type propane heaters are inexpensive as well but if the garage is fairly tight they can cause a problem as they need a fresh air source.
Most gas companies will supply the tank, most at no cost. Propane running about $3.10/gal here in NewEngland. You can run your own line but should have it inspected before you fire it up.
Mr. Heater Natural Gas Garage Heater — 75,000 BTU, Model# MHU75NG | Natural Gas Heaters | Northern Tool + Equipment
Old Dec 4, 2010 | 09:05 PM
71 Sport Custom's Avatar
71 Sport Custom
I've got a small 14x20 shop here at the house. well insulated. Kerosene and unvented lp had you walking into walls in no time. Electric radiators got it nice and toasty just in time to come back in the house for the night. Set a high efficiency lp house furnace. It pulls in outside air for the burner and exhausts through pvc. Its around 70 or 80k btu. It does the job!!! You're gonna need a furnace and central ac for that big shop.
Old Aug 11, 2011 | 09:55 PM
tofer76's Avatar
tofer76
i got a great deal on a used electric furnace and central ac unit then i sold the ac unit for more than i paid for the both wasnt going to use it anyway mines 24x 40
GSDSROK
Jan 2, 2013 04:34 PM
honaker-texas
6.7L Power Stroke Diesel
Oct 30, 2011 09:53 PM
Daddyo's garage
Dec 6, 2009 05:18 PM
dirtriderdan
Garage & Workshop
67
Oct 18, 2004 04:35 PM
97F-150Hal
1997 - 2003 F150
May 19, 2004 08:04 PM
