Alternator Brackets Help
Old Nov 27, 2010 | 10:10 PM
Scoop531's Avatar
Scoop531
Working on my 79 F250 with a 351M that i just repurchased after selling it a few years ago. The last owner did a 3G swap right before I got it back. After looking it over I noticed the alternator pulley and the crack pulley were way way off and the brackets dont seem right. Anyone have a pics of thiers? Or did he forget to swap brackets? or use the wrong brackets? So if anyone could give me info on what brackets I need to use as i was planing to make a trip to the junk yard in the AM maybe ill grab a set off another truck. Any pics of your alt installed and the belt setup would be helpful as well
Old Nov 28, 2010 | 03:26 PM
Scoop531's Avatar
Scoop531
Anyone? ??
Old Nov 28, 2010 | 03:50 PM
HIO Silver's Avatar
HIO Silver
Do a search in this forum for "3G". There was a thread on it not too long ago.
Old Nov 28, 2010 | 07:31 PM
hairyboxnoogle's Avatar
hairyboxnoogle
From what i have seen looking into it myself, all you need is the correct alternator and it is a direct swap. You may have to re-clock the Alt. or change pulleys but thats it.
Old Nov 28, 2010 | 07:34 PM
steponit's Avatar
steponit
Post the numbers stamped on the alternator case.
I suspect this alternator was meant for a different application
Old Nov 29, 2010 | 10:53 PM
Scoop531's Avatar
Scoop531
Houston we HAD a problem!! Well after a quick trip to the upull it yard I picked up a bracket off another truck and it seems to work. ( Havent installed it just eyed it up and tried to hold everything together at once LOL) So im hoping thats the end of that mess. I think the last owner tossed the correct one when he started replacing/painting the engine bay.
