Driveline choices
Old Nov 27, 2010 | 08:25 PM
84fordor's Avatar
84fordor
Driveline choices
Hey guys, new here, just had a few questions that may seem kinda dumb, but I am not all that familiar with trucks from the 80's. I used to build 74-78's quite a bit, but this is my first post-80 4x4.
I have an '84 F350, that originally had a diesel in it. I was planning on putting the 460 and four speed out of my 78 bronco in it, but did some measuring and found out that the trans, transfer case combo is gonna come up WAY short to hook up the rear drive shaft.
So, my question is, does anyone know if the four speed out of my '78 will bolt up to an '80s era transfer case, or am I gonna have to come up with a trans, to? I would like to put a five speed in it, but have not been able to come up with a donor truck that I can afford.
Any suggestions??
Old Nov 27, 2010 | 08:32 PM
Franklin2's Avatar
Franklin2
Yes, all transfer cases interchange, the pattern and the splines are all the same, except the very late model truck transfer cases(late 90's I think, way later than you are messing with).
The big differences are like you found; different lengths, different shifters and shifter locations. That 460 should fit if you get the correct mounts from a truck that had a 460. Your diesel crossmember is the 460 type that clears the oil filter, though you still may need a adapter to turn the filter at the correct angle. It all should bolt in with the correct parts, since 83ish-up trucks had a 460 as a option.
Old Nov 27, 2010 | 08:35 PM
taisa899's Avatar
taisa899
could just have a new driveshaft made up. I had to do it when I replaced my E4OD with a C6
Old Nov 27, 2010 | 08:51 PM
84fordor's Avatar
84fordor
Thanks for the info guys!
Yes, I had contemplated just having the drive shaft from the carrier forward lengthened, but I am trying to keep it cost effective, and and looking into the future, in the unfortunate event that I have to replace it, I would have to make one again.
I have actually welded up my own driveshafts in the past, but I plan on taking this truck on long trips with the family, so I would rather have everything as sound as possible. Also, again, if I break down, it would be nice if I could just go anywhere close by to get parts.
Thanks again for the great help......
Speaking of which, anyone know where I could find rear door panels for the early 80's crew cabs? I am guessing that they must have been conversion trucks perhaps? Having a hard time tracking them down for these years.
