Speedometer reset ##
Old Mar 1, 2003 | 11:25 AM
standman's Avatar
standman
Question Speedometer reset ##
From my calculations I come up with 8.61 for 32/11.50-15LT BFG/MT.BFG says 654 revs per mile but I come up with 638.I want
to change mine from 9.72. Any help would be appreciated.93 F150/5.0-E40D/3.55
Thanks
Standman
Old Mar 1, 2003 | 12:10 PM
steve83's Avatar
steve83
https://www.ford-trucks.com/forums/s...hreadid=100109
Old Mar 1, 2003 | 02:28 PM
mrwizard's Avatar
mrwizard
How did you come up with your figure for revs/mile? If you calculated the numbers based on the height of the tire (31.8?) then it will probably be a little off because of the deflection that happens to the tread on the road.
Old Mar 1, 2003 | 04:18 PM
standman's Avatar
standman
Smile Speedometer reset ##
RevsperMile = 20168.11439/TireHeight
mrwizard= How do you calculate the ### and what ### did you come up with???
Thanks
Standman
Old Mar 1, 2003 | 05:28 PM
mrwizard's Avatar
mrwizard
That is the right calculation, but... Because of all of the stresses that are exerted on a tire by the weight of the vehicle, the flex in the rubber, etc... the calculation probably isn't going to be exactly what the results will be in actual use. I would just use the rev/mile figure from BFG. I'm sure they've done some serious testing to come up with those numbers.
Just FYI, I came up with 634 using 31.8" tire height.
