Please Help Tapping Noise
Old Nov 27, 2010 | 02:06 PM
THEW1LD's Avatar
THEW1LD
I have 2001 f250 and I changed the oil and fuel filter and a few weeks later the truck has a slight miss and a tapping noise i have read alot of helpful tips from everyone so i decided to join this is my first time so if anyone could help i hate to take it to ford Thanks
Old Nov 27, 2010 | 02:22 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
What kind of oil did you use? Is it full?
Old Nov 27, 2010 | 02:53 PM
woodnthings's Avatar
woodnthings
Is the miss at idle or throughout the rpm range?
As stated above.....Which oil did you use?
Where is the tapping coming from? (Top, bottom, sides???????)
Old Nov 27, 2010 | 03:00 PM
THEW1LD's Avatar
THEW1LD
I used rotella T I let it run and checked it it was full It started when i changed oil and fuel filter It was fine for three weeks then started missing at idle and when accellerating and has a tapping noise now Thanks for the reply sorry the tapping is on drivers side top I did a buzz and contribution test the buzz passed and the contribution test failed #8 so I changed # 8 and still the same
Old Nov 27, 2010 | 03:04 PM
woodnthings
Did you use synthetic or dino and what weight?
It may be unrelated, you may have something else going on too. Need some more info though.
Where are you located?
Old Nov 27, 2010 | 03:07 PM
THEW1LD's Avatar
THEW1LD
dino 15 /40 im in salem IL
Old Nov 27, 2010 | 03:32 PM
THEW1LD's Avatar
THEW1LD
does a injector make a tapping noise just wondering Im new first diesel owner Thanks
Old Nov 27, 2010 | 03:33 PM
woodnthings
Changed #8 injector? You probably shouldn't have done that. #8 will fail the CCT if you have a gray cam position sensor (CPS) which you most likely do, as they had a recall for them and went to the new gray ones, which fail the CCT. Who did the work, you or the dealer? If it was a ford dealer, they should know better, and if it didn't fix your problem they surely shouldn't have charged you for it.
Old Nov 27, 2010 | 03:35 PM
woodnthings
They can, depends on what is going on. Usually they are louder when cold, but once it warms up, it should sound "normal".
What did you do the Buzz and CCT tests with?
Old Nov 27, 2010 | 03:38 PM
woodnthings
Old Nov 27, 2010 | 03:40 PM
THEW1LD's Avatar
THEW1LD
A snap on scanner tapping noise is quite when cold but when it warms up it is louder Thanks alot for replies sorry the dealer did work can i remove the valve covers and unplug each injector to see if tapping noise goes away just wondering
Old Nov 27, 2010 | 04:51 PM
KH85's Avatar
KH85
Does it run fine other than the miss at idle and when accelerating? Will it gain speed and shift normal when you mash on it?
Old Nov 27, 2010 | 06:18 PM
THEW1LD's Avatar
THEW1LD
Sorry yes it runs and shifts fine just dont seem to have all the power there
Old Nov 27, 2010 | 07:15 PM
F350-6's Avatar
F350-6
Who has the snap on scanner? Can you watch perdel readings on it?
Yes you could unplug one injector at a time. You should be warned that the wiring carries 110vdc and carries some risk when playing with electrical stuff, but many people do this type of test. Keep in mind that when you unplug an injector it will cause the engine to miss so you'll have to try to ignore that while diagnosing. You also run the risk of taking one injector off line decreasing the oil demand in that rail and thereby making the noisy injector quite.
if you go this route, start by at least observing the oil discharge from each injector. If you have one injector not spitting oil the same as the others, that would be the suspect injector.
A miss should have shown up on a contribution test. Did the miss start right after the oil change or when the temps got colder? How long have you had the truck? If you get on the freeway and hold the speed at 55 or so and then let off the gas, does the ticking noise go away? Any chip or tuner on the truck? Any other mods?
Old Nov 27, 2010 | 08:15 PM
THEW1LD's Avatar
THEW1LD
thanks I didnt know that so i will watch the oil from the injectors first yes the miss started after oil and fuel filter change I have had the truck for 3 months
