SBF crank pulley questions
I am building a 351w for a small hotrod project. I am using budget/junkyard parts as much as possible. I found a crank pulley I want to use (because it's a 3 groove) and the part number is D3AE 6312 EA
Do the pulleys themselves have anything to do with the engine balance? Can I use a 302 pulley (not balancer) on a 351w and vice versa.
Even if they were from a 302, the D3 part number means they're from an early 302 with a 28oz imbalance anyways right?
The reason I ask is the crank pulley is a large iron one and not a stamped steel one like some other Ford engines.
wrong, it means it was designed for an engine in that year.
The suffixes are what determines what year it is fromn
That is a stamping or engineering number not really a part number.
Unless it is a combo harmonic balancer/Pulleys then you can use it on anything
The cast iron piece should have counter weights on it to keep it run true
I believe the pulley's have nothing to do with balance.
The 351W and earlier 302 are 28oz externally balanaced engines. Balanced externally with the Flywheel and harmonic balancer. Note the balancer and the flywheel can only be mounted in one position. Keyway on the balancer and the bolt pattern on the flywheel only allow for one position for mounting.
Now the pulley on the other hand has four holes and can be mounted in any of the 4 positions.
abyars111
Oct 8, 2015 12:05 PM
dresden78
Mar 23, 2015 02:32 PM
yellow 79
Apr 1, 2009 05:24 PM
