Transmission Trouble
Old Nov 27, 2010 | 10:02 AM
vewilliams's Avatar
vewilliams
Question Transmission Trouble
I have a 2001 Ford Excursion 7.3L Diesel automatic. The transmission started out not going into overdrive. Then the OD light started flashing, not constantly, and the other night I started to back up and the vehicle just stopped like it went into neutral. I pulled forward and it stopped again like it was in neutral, I did that a couple of time and then when back to reverse and it backed up just fine and the gears changed good. Does anyone have any advise?
Old Nov 27, 2010 | 10:21 AM
ScaldedDog's Avatar
ScaldedDog
Get the codes read, as it *might* just be a sensor gone bad. Sounds like it might be time for a new or rebuilt tranny, though. I've got the same vehicle you do, and just put a BTS in it.
Mark
Old Nov 27, 2010 | 03:16 PM
bluescrew's Avatar
bluescrew
whens last time u changed tranny fluid
Old Nov 27, 2010 | 04:32 PM
KH85's Avatar
KH85
X2 on the fluid change. If its due for a change you may want to change it. When you change the fluid it'll give you a good idea of the condition of your trany. You'll be able to see how much of your clutch packs are sittin in the bottom of the trany.
And if its in bad shape it may get worse when you change it. Then you'll know you need a new one.
Old Nov 29, 2010 | 09:29 AM
vewilliams's Avatar
vewilliams
Transmission fluid changed 1st of November. Wife took to to xpress lube so I did not get to see it.
Old Nov 29, 2010 | 11:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Get the codes read. Changing the fluid is a waste of money right now. You need to see what the codes say before doing anything else.
Old Dec 2, 2010 | 01:46 PM
vewilliams's Avatar
vewilliams
About a week ago it threw a code showing is was slipping between 3rd and 4th gear. A mechanice has had it since Tuesday of this week and has been driving it. He say it is not showing any codes now and is running fine.
