Question about coolant
Old Nov 28, 2010 | 08:10 AM
teppler's Avatar
teppler
Originally Posted by roadrunner01
one of the problems with the first generation 6.0's were the block heater element flaking and leading to blockage of the oil cooler. international's fix to the problem was installing a coolant filter, i think, prior to '05.
First time I heard about block heater flaking off and plugging cooler is this something new?
Old Nov 28, 2010 | 10:59 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by bismic
This is only an opinion but ...........
It has to be more than a bad design (and I am certainly not arguing the bad design part) - however too many people w/ high mileage and ZERO problems. What an interesting "puzzle".
Those were good links hubler13f - thanks.
Very interesting links, Jeremy. Thanks for providing them.
Yes, what a conundrum. It would be interesting to know what the high mileage no problem people are running although I'm sure you could put a "bell curve" to the whole class of high mileage trucks failure wise for repairs. I'm pretty amazed at how much crap I'm still getting out of my cooling system after all this time and miles, so the cooler failures don't surprise me.
Old Nov 28, 2010 | 11:01 AM
npccpartsman
Nope, it's not new, I just don't know if it's founded or not. It's been a long time since I first heard it and I'm fairly certain if it was a true problem it would be "on the boards" quite a bit. I almost never see it discussed anymore.
Old Nov 28, 2010 | 11:45 AM
hubler13f's Avatar
hubler13f
There is an 1 1/4" or 1 1/2" coolant hose that connects to the front engine cover on the driver's side. It kind of blocks the banjo bolt fuel line connection to the head.
The last time I tore my truck down that far, I looked into that metal tube and noticed a huge 1"x1" chunk of powder coating that was flaking off of the inside of that tube. I reached in with a pair of needle nose pliers and pulled it out.
Imagine how bad that could have clogged those coolers!
Old Nov 28, 2010 | 06:39 PM
roadrunner01's Avatar
roadrunner01
from what was listed in the link in one of the above posts, the block heater element wasn't upgraded until jan of '06 production.
Old Dec 16, 2010 | 08:50 PM
GTRider's Avatar
GTRider
Sooooo, with all this talk about coolant, sounds like no one really knows what's in some coolants that could be bad or what I should look for in a coolant?
GO5 has silicates in it. Dexcool does not. But I read here not to use Dexcool. Huh?
From what I've read, after chemically flushing the system we should be able to use the OAT ELCs, sound right? CAT or Texaco ELC is what I am looking at. I also found Zerex ELC which is Dexcool compatible and silicate and phosphate free. Thoughts
I did find this thread which had some good info but still a debate.
https://www.ford-trucks.com/forums/6...procedure.html
06FUN
Oct 29, 2016 07:53 AM
Grinder Man
Oct 10, 2014 09:35 AM
ten.mile
Dec 11, 2012 05:56 PM
Navistar Diesel
Jul 28, 2012 07:03 AM
TGO
Feb 25, 2008 04:34 PM
