High beams and Turn signals not working
03-16-2014, 10:53 AM
on
The turn signals and high beams do not work on my 1998 ford ranger xlt 4x4. I have replaced the multi function switch, the yellow flasher relay checked all fusses and all are good. What could be the problem?
03-16-2014, 02:59 PM
Does the high beam indicator light up?? If it does you probably have 2 burned out bulbs. If it does'nt, does flash to pass work?
If it's also not working, double check interior fuse 33
03-16-2014, 07:59 PM
on
High beam indicator does not light up and flash to pass does not work either and I will double check fuse #33.
Thanks, for the info
03-17-2014, 03:04 PM
I just noticed theres also a flash to pass only fuse under the hood in the fuse/relay box. Could'nt hurt to check it to. It's mini fuse 12.
03-17-2014, 04:56 PM
on
I fixed the hi beams I over looked a fuse that was missing. Replaced it and they work but still having problems with turn signals not working.
03-17-2014, 06:28 PM
Strangely enough I cant find the 98 turn signal diagrams.
Theres probably 2 fuses feeding a single electronic flasher. One fuse for the hazards and another fuse for the turn signals. Check them.
Are the hazards working?
03-17-2014, 07:49 PM
on
The flashers do work, and I can't find a listing for the second fuse for the turn signals. thanks for all the help
03-18-2014, 02:18 AM
Glad I could help & congrats on fixing the high beams.
Not sure if this is right, but I think the fuses feeding the flasher are interior fuse 10 for turn signals & 21 for the flashers.
If you have a Ford dealer nearby see if the parts dept. will print you a copy of the turn signal diagram.
Reason: more info
E30tdf
Electrical Systems/Wiring
05-17-2014 12:55 AM
WhuddaGuy
1999 to 2016 Super Duty
07-20-2012 11:52 PM
Aggie05
Bronco II
19
04-04-2006 03:49 PM
javieljb
06-06-2005 08:35 PM
scanmike
1983 - 2012 Ranger & B-Series
04-14-2003 10:04 PM
