(ABS)light
Old Nov 26, 2010 | 10:15 AM
bulla's Avatar
bulla
(ABS)light
Does anyone know why my ABS light comes and goes? It doesn't flicker it just comes on for a few hours then goes away for a few days then it comes back on for a few hours then goes away again. Sometimes all I have to do is restart my truck and in a few seconds it goes away and sometimes it goes away by itself. I don't think it's causing any problems as everything seems to be working just fine but the light can be a little distracting. Any thoughts?
Old Nov 26, 2010 | 10:26 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Wondering if one or more of the sensors might have some trash on the end of it?
Old Nov 26, 2010 | 10:28 AM
Jager's Avatar
Jager
Are you sure your ABS is working when the light comes on? I would suggest checking that first. I recently had the same issue. It was the vehicle speed sensor (VSS) on top of the rear differential. This sensor is a common problem for ABS issues. It was a 15min fix and cost around $25.00. I found it easiest to remove the spare tire when doing this fix. Also becareful of the electrical connection as it is brittle when you remove it. Another FYI is some people on here have had luck just removing the sensor, cleaning it, and then reinstalling. I figured it was worth the effort to do it twice for $25.00.
Old Nov 26, 2010 | 10:34 AM
Franko72's Avatar
Franko72
Molon Labe
My ABS light would come and go. I replaced my VSS also and that fixed it.
Old Nov 26, 2010 | 10:54 AM
bulla's Avatar
bulla
Thanks guys. How would I check if the abs is working?
Old Nov 26, 2010 | 11:03 AM
clintbonnie's Avatar
clintbonnie
Napa sells the ABS sensor (VSS) , p/n 530780 .. was about $12 a couple years ago..
Old Nov 26, 2010 | 11:06 AM
Jager's Avatar
Jager
What I did was when the ABS light was on I found an area where no one was behind me and would get the truck up to 25 mph and anchor the brakes. If you don't feel the brakes pulsing from the ABS working then you know you have a problem.
Old Nov 26, 2010 | 11:40 AM
SpringerPop's Avatar
SpringerPop
Wet streets are a good place to check ABS.
Pop
Old Nov 26, 2010 | 11:44 AM
bulla's Avatar
bulla
Considering it's raining that shouldn't be a problem. Wow that was scary I just dis it coming to a stop sign. Locked up all 6 tires and killed the engine. What's up with that? Funny thing is the light wasn't on and still isn't now. I think I'm gonna start a new post about it dying!
Old Nov 26, 2010 | 12:15 PM
clintbonnie
Killing the engine at a stop sounds like it could be related to your torque converter..
Old Nov 26, 2010 | 12:57 PM
SpringerPop
Also remember that on some trucks the windshield wipers affect the CPS's ability to properly track it's "windows" on the cam gear.
If you turn them off do you have different results?
Pop
Old Nov 27, 2010 | 09:39 PM
f250bravo's Avatar
f250bravo
Had same issue with abs light. Replaced rear speed sensor as it was the likely culpret and cheap to fix but that did not fix it. Had to get service shop to read diagnostics codes for $30 since auto zone free diagnostics readers don't read abs codes. Had to replace front left abs sensor to fix it but that ran me about 80 bucks.
bluegroove
1983 - 2012 Ranger & B-Series
Jan 2, 2013 10:45 PM
Zirk
Jan 21, 2009 10:19 PM
2K3 Mach
Nov 3, 2004 11:23 AM
acerockola77
Feb 15, 2004 12:25 PM
Redjackt88
Feb 20, 2003 06:53 AM
