HG job recently
Old Nov 25, 2010 | 08:38 AM
vloney's Avatar
vloney
HG job recently
Just did one that with the pressure gauge hooked up, the pressure would rise in the degas bottle to 21 psi IN THE BAY AT HIGH IDLE!
Old Nov 25, 2010 | 08:40 AM
hubler13f's Avatar
hubler13f
What is normal?
Old Nov 25, 2010 | 08:48 AM
vloney's Avatar
vloney
16 psi max (specs on the cap)
Old Nov 25, 2010 | 01:49 PM
ehgeeray's Avatar
ehgeeray
This is obviously with the pressure tester hooked in-place of the degas cap?
Old Nov 25, 2010 | 02:26 PM
cheezit's Avatar
cheezit
yes but its just as accurate and is a great way to test under no load. it provides the info we need. I have 30 psi in my bay before
Old Nov 25, 2010 | 04:58 PM
ehgeeray's Avatar
ehgeeray
Did you use Black ONYX Gaskets?
Old Nov 25, 2010 | 05:33 PM
cheezit's Avatar
cheezit
my guess is no being its no his truck. hes a ford tech as well so that leads me to belive it was a customers
Old Nov 26, 2010 | 07:39 AM
vloney's Avatar
vloney
No reason to use anything other than stock. Used bolts too!
Old Nov 26, 2010 | 07:54 AM
tex25025's Avatar
tex25025
I will agree with the gaskets form 90% of applications out there. However, that percentage goes down with regard to bolts.
Old Nov 26, 2010 | 07:59 AM
vloney's Avatar
vloney
Never had a comeback! Oh, Morning Tex!
Maxium4x4's Avatar
Maxium4x4
Even the Master Tech got it wrong, the head gaskets did not fail, the torque to yield bolts failed.
Hi Vince.....
Old Nov 26, 2010 | 08:13 AM
tex25025's Avatar
tex25025
Don't confuse not having a comeback with a flawless record. I rarely go back to people that I've had issue with how they did things. It's not worth the time nor money to fight it either, even if the issue happened within mere days or weeks from the time of the initial work.
I am not saying that's the case, just don't confuse not having a comeback with the owner not having a problem later on in of itself.
Like I said, it depends on the application of the truck with regard to how well the TTY bolts hold up. Stock applications, if done correctly, TTY bolts will be more the adequate, however, be realistic, how many owners of the 6.0s have stock programmed trucks? Not many, depending on what tuners they've used, that adds even greater risk to the TTY bolts. I am not blaming the bolts for that, but you have to realize that the truck has a different application then the stock configuration, thus stock parts may or may not be up to snuff.
Old Nov 26, 2010 | 08:15 AM
tex25025's Avatar
tex25025
Hi Vince.....
That slipped by me. You are right, 508HP and my stock gaskets are doing great. Try that with the TTY bolts, I don't think so.
Old Nov 26, 2010 | 08:25 AM
Maxium4x4's Avatar
Maxium4x4
Same here Tex...... Stock gaskets are holding good once nailed down properly. Still checking heads with a straight edge anyone?...... What Ford says is acceptable is not always the best remedy but again when you work for a dealership your hands are tied.
Old Nov 26, 2010 | 08:51 AM
vloney's Avatar
vloney
Where the flash is the sealing material was gone allowing combustion gasses into the coolant passages.
