Sponsored by: Auxito
4wd doesnt work! snow is here, help!
Old Nov 24, 2010 | 07:54 PM
slow_v6_stang's Avatar
slow_v6_stang
a little background information...
it is a 2004 F-150 XL 4.2L 5-speed 4X4. the 4wd shifter is on the floor (no electronic ****). the truck has 34,XXX miles on it, i bought it on 8/3/2010 with 27,XXX miles on it.
i can put it in 4wd low, but it is just the rear tires that spin (so it is actualy a 2wd low). there is no "4X4" light that lights up in the dash when i put it in 4wd. it is basically acting like someone took the 4X4 light out of my dash and like someone removed my front driveshaft. i am assuming that there is a light in the dash that shows that you are in 4wd at least...
any clues as to what the heck is going on here??
Old Nov 25, 2010 | 12:38 PM
Cdy1's Avatar
Cdy1
did it work when you bought it? if so did it make any noise when you tried to use it?
Old Nov 26, 2010 | 03:26 PM
93 mix 'n match's Avatar
93 mix 'n match
thats why you ALWAYS check the 4wd before you sign.
Old Nov 26, 2010 | 05:42 PM
slow_v6_stang
this is my first time trying to use the 4wd. i had no use for it in the dry summer months on the road.
thanks for the help
Old Nov 26, 2010 | 06:21 PM
93 mix 'n match
put the truck up on jackstands, put it in 4wd, and see if the front driveshaft is spinning. if it is, then its a problem with the vacuum activated front differential. if it dosent, then your T-case is toast.
MDH73
Mar 3, 2015 02:09 PM
$kippy001
Jan 7, 2009 11:44 AM
rurbanski
33
Oct 15, 2004 10:13 AM
pender
Aug 14, 2002 11:00 PM
