Thermactor System Schematics
Old Feb 28, 2003 | 10:05 PM
gslk1214's Avatar
gslk1214
I am looking for a diagram of the all the vacuum ports on the thermostat housing. What do they all do?? does one control the heater box motor on the air cleaner along with the bi-metal switch?? If anyone has a diagram, could you send me one??
Thanks for help, and again this forum is excellent.
Gord gord@dycksdrugs.com
Old Feb 28, 2003 | 10:23 PM
Mil1ion's Avatar
Mil1ion
What engine and does the trruck live in Calif?
Old Feb 28, 2003 | 11:18 PM
jkhaltom's Avatar
jkhaltom
I could use the same info. My new carb should show up tomorrow and I was noticing tonight that some of the vacuum hoses are rigged. I especially need to hook up the AC/heater vacuum hose. My distributer advance seems to be working correctly with the heat of the engine though... I got that much right. Mine is a '76 360 2V.
P.S. I had to change the diaphram(accelerator pump, power valve or whatever its called) on my carb because it sprung a bad leak. For some strange reason I gained about 30 horses. I can spin the 36.5s now.
Still changing the carb though,.. can't live without a choke!
Old Feb 28, 2003 | 11:31 PM
gslk1214's Avatar
gslk1214
Sorry I forgot to include the info.
1979 F-250 S/C 351M C-6
Thanks for your help, Gord gord@dycksdrugs.com
gordpye
Nova Scotia
Nov 29, 2004 12:44 PM
gslk1214
General Automotive Discussion
Apr 18, 2004 08:14 PM
Gord
Jun 7, 2002 09:30 AM
Gord
May 31, 2002 05:11 PM
