Sponsored by: Real Truck
lower dash
Old Nov 24, 2010 | 12:06 PM
xmontex4's Avatar
xmontex4
lower dash
Hey guys I have an 04 F250 and I wanted to put a bull bar with fog lights on but I don't want to drill into my dashto install a switch so I figured id look into the 05 lower dash with the upfitter switches and the driver side glove box, I was wondering how much it would cost if there's any modification etc. Any info you guys have would be great thanks.
Old Nov 24, 2010 | 12:28 PM
Wagion's Avatar
Wagion
Something else I have seen done is get a piece of aluminum diamond plate and mount it up under the dash so it hangs down then you can drill and put switches on it any way you want.
Old Nov 24, 2010 | 02:24 PM
xmontex4's Avatar
xmontex4
That's a cool idea, I was thinking of making it more factory but im still not sure the diamond plate does sound nice, my cousin wants to drill right into the dash lol but im not a big fan of that.
Old Nov 24, 2010 | 03:01 PM
Wagion's Avatar
Wagion
Yeah there is a bunch of stuff I have not done to my truck at all becasue I refuse to drill any holes in it. Mine came with upfitter switches so that made it a little easier. Still refuse to drill holes in sheet metal or dash thought finally found mud flaps from WeatherTech that don't require drilling any holes. Still trying to figure out how to mount antennas
Old Nov 24, 2010 | 03:08 PM
xmontex4's Avatar
xmontex4
Yeah im the same exact way I don't wanna drill any holes. My buddy helped me install my headunit and he kept insisting the plastic piece between the stereo and the climate controls had to come out so I finaly gave in even tho I was against it and I ended up being right and now my dash is kinda screwed up so I've gotta fix that, but that's my reasons against it lol. I figured the upfitter switches if it can just be like swapped would be a good choice for no drilling etc.
Old Nov 24, 2010 | 04:04 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Ever think about the F650 lower dash?
Riffraff Diesel: Riffraff Custom Auto Dash Kit
https://www.ford-trucks.com/forums/7...duty-pics.html
Old Nov 24, 2010 | 04:24 PM
Wagion's Avatar
Wagion
2005-07 Upfitter kit for $103 plus shipping
www.partsguyed.com
Old Nov 24, 2010 | 06:16 PM
djpahan's Avatar
djpahan
i found craigslist posting for parting out 07 f350. i got lower dash with switches $80 shipped from Portland to Seattle. went into my 99 with bit of trimming.
Old Nov 24, 2010 | 10:24 PM
xmontex4's Avatar
xmontex4
I have actualy looked at the 650 dash that's my other consideration, but as far as the 05-07 dash goes does the grey match the 04 grey? And if its the one with the glovebox on the driver side is there alot of modification or just some trimming to be done for that?
Old Nov 24, 2010 | 11:08 PM
Waltdog's Avatar
Waltdog
of American machinists
I did the lower 05 dash in my 02
Here is the thread I started
https://www.ford-trucks.com/forums/9...fo-needed.html
Lots of good links in the thread
Old Nov 24, 2010 | 11:16 PM
Waltdog's Avatar
Waltdog
To buy all of the parts required for upfitter w/ driver side glove box is going to be about $300 if you bought the parts brand new.
There are ways to install the upfitters in a pre 2005 lower dash, it does however leave you to come up with a filler piece on the right hand side of the switches.
To install A lower 05 dash in your truck is going to require some holes to be drilled in the metal framework under the dash. Also moderate amounts of plastic trimming on both your current sub dash and a bit of the lower 05 piece.
The thread I linked to has good info, here are the links
Installing Upfitter Switches - Ford 2005-2007 Superduty
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
https://www.ford-trucks.com/forums/7...ml#post5885336
Old Nov 24, 2010 | 11:24 PM
freekyFX4's Avatar
freekyFX4
The upfitter switches are nice, but unnecessary. Just add some switches on a piece of diamond plate, like you suggested.
Old Nov 25, 2010 | 01:23 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by amdriven2liv
I really like my F650 Dash from Riffraff. I needed a place for 3 upfitter switches, 3 gauges and a place for my air compressor switch and air release valve. Worked out great!
Old Nov 25, 2010 | 02:11 AM
bmaruska's Avatar
bmaruska
I am the same way when it comes to drilling holes. But, I did drill a hole in the fuse panel door under the steering wheel to put in a rocker switch that powers the fuel tank in our '06 diesel. Kinda handy to be honest. I don't hit it with my knee and it doesn't stick out like a sore thumb.
Old Nov 25, 2010 | 01:18 PM
xmontex4's Avatar
xmontex4
thanks guys thats alot of help. i dont mind drilling and trimming behind the dash im more of an in sight kind of person lol ill post some pics of my dash and you';.ll see what happened when my buddy installed my headunit which turned me away from drilling etc lol
