wiring diagram
Old Nov 24, 2010 | 04:28 AM
beersy50's Avatar
beersy50
wiring diagram
I'm looking for a wiring diagram of the fuel guage all the way to the tanks and every thing in between. I'm sick and tired of guessing how much fuel I have. thanks for any help.
Old Nov 24, 2010 | 04:32 AM
rupejosh's Avatar
rupejosh
probably just need a new float
Old Nov 24, 2010 | 04:33 AM
Skip1970's Avatar
Skip1970
i camt help you there, but if you get a stick and poke a hole in the top of the tank you can measure it with a stick then you aint gotta guess.
Old Nov 24, 2010 | 04:40 AM
beersy50's Avatar
beersy50
well the hole in the top of the tank would also help my filling problems. The 2 local gas stations have the high volume pumps ( which have the large nozel) with the nozel in there there is no room for air to get around it so it burbs and spits fuel at me.
The guage dosen't work for either tank...so both floats are bad?
Old Nov 24, 2010 | 04:52 AM
Skip1970's Avatar
Skip1970
probably your valve, as it switched the wire too if your using the stock electric valve anyhow
Old Nov 24, 2010 | 05:15 AM
beersy50's Avatar
beersy50
your saying the tank selctor valve right? I know that works enough to switch between tanks anyway.
By the way How do you like your Ex? My wife and I would like to get one.
Old Nov 24, 2010 | 05:21 AM
Skip1970's Avatar
Skip1970
i like it allot, would like it more if i fixed all teh oil leaks!
Old Nov 24, 2010 | 05:27 AM
beersy50's Avatar
beersy50
can an adult fit comfortly in the third row?
Old Nov 24, 2010 | 05:40 AM
Skip1970's Avatar
Skip1970
yes they can! same size as rest seats just a little less width
Old Nov 24, 2010 | 06:00 AM
Cruickie's Avatar
Cruickie
Hope this helps!
Cruickie's Avatar
Cruickie
Doesn't look like that worked so here is the link to the picture I tried to add:
Ford Truck Enthusiasts Forums - Cruickie's Album: Service and repair images - Picture
Old Nov 24, 2010 | 04:30 PM
beersy50's Avatar
beersy50
You Da Man Cruickie!! Thanks alot. Hey here's another question for you: Will the instrument cluster from a gasser work in this truck? I know the Tach will read higher than 4,000 rpms but will it still read corectly? I'm thinking that might be part of my problem seems how the only 2 guages that work are the amp guage and the oil pressure guage.
Old Nov 24, 2010 | 05:50 PM
rodneywar's Avatar
rodneywar
nope cause the gasser gets a different signal that the diesels tach sensor puts out
Old Nov 24, 2010 | 11:56 PM
PLC7.3's Avatar
PLC7.3
See if these # work for your gauge.........
Here are the fuel guage test #s for the 93
22 ohms sent to the guage it reads empty "E"
145 ohm sent to the guage it reads full "F"
Here are the sender test #s
Sender at empty stop 14-18 ohms
Sender at full stop 154-162 ohms
Old Nov 25, 2010 | 06:57 AM
beersy50's Avatar
beersy50
I'll try them as soon as I can Thanks alot.
