6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
alarm problem
Old Nov 23, 2010 | 08:04 PM
WorkhorseF250's Avatar
WorkhorseF250
alarm problem
hey parents have a 2010 f350 6.4l and they are having issues with the trucks alarm going off when the lock it, they also have problems with the alarm going off when the truck is started with the command start. it shuts down after 10 15 mins and a few mins later the alarm goes off. anyone have this problem?
Old Dec 21, 2010 | 12:21 PM
Beene's Avatar
Beene
Factory installed unit or Aftermarket?
Old Dec 21, 2010 | 02:02 PM
WorkhorseF250
It is a factory installed alarm system from ford. The only way to stop the alarm from going off is by locking it manually
Old Dec 21, 2010 | 05:38 PM
WorkhorseF250
does anybody else have this issue with there alarm system? i dont know if this makes a difference in the problem, the truck is a Cabela f350 crew cab.
Old Dec 21, 2010 | 07:18 PM
Beene's Avatar
Beene
Well the short story is take it in. The long story sounds like they haven't hooked up something properly. Although I have never seen a factory(not dealer installed but actually factory installed) alarm in these trucks, the more loaded they are, the higher the likely hood it has one. Sounds like the have 2 seperate units installed rather then one single alarm/starter combo. Typically when you have 2 units you have to isolate the ignition wires from the alarm on start up and may also have to do the same to the shock sensor other wise the truck can vibrate enough to set the system off. Could be wrong but if it worked before then the only other thing I could think of would be a broken wire. I spend my days fixing poorly installed factory alarms. Not trying to pick on ford's techs but some of them don't belong on the electrical side of things. This is also very true about A LOT of the worlds car installers but that's another rant altogether Could be a whole bunch of things that are causing the problem but the short of it is that you should have warranty so it's better not to mess with it. Especially if you are unsure about what you're doing.
Diesel Submariner
25
Aug 20, 2013 09:27 PM
WorkhorseF250
Nov 23, 2010 10:12 PM
tgr8st
Mar 20, 2010 01:20 PM
jmusenkh
1997 - 2003 F150
Sep 21, 2006 01:47 PM
noyield
Oct 7, 2003 07:10 AM
