differential seal
Old Nov 23, 2010 | 07:23 PM
flossy's Avatar
flossy
Question differential seal
i would like to know if there is a differential yolk seal for a 2002 edge
Old Nov 23, 2010 | 07:25 PM
flossy's Avatar
flossy
if someone knows the answer to my question please reply..... when replacing a pinion seal does the yolk have to be torked ??????
Old Nov 23, 2010 | 07:30 PM
flossy's Avatar
flossy
what is the tork ratio when replacing pinion seal
Old Nov 23, 2010 | 07:31 PM
flossy's Avatar
flossy
when replacing the pinion seal on a ford edge 2002 is there a tork ratio you have to set it at
Old Nov 24, 2010 | 12:22 AM
g_k50's Avatar
g_k50
My 2001 Service Manual shows a "Rear axle drive pinion seal" for a Ford 7.5 rear drive axle/differential. Is that what you're looking for?
Old Nov 24, 2010 | 12:30 AM
g_k50's Avatar
g_k50
Service manual instructs to set the pinion nut to the same torque as originally recorded during disassembly.
Quote, "Rotating the pinion through several revolutions, take frequent cone and roller bearing torque preloading readings until the original recorded preloading reading is obtained."
Pinion bearing preload (used pinion bearings) 0.9-1.5 Nm 8-14 ft-lb
Pinion bearing preload (new pinion bearings) 1.8-3.3 Nm 16-29 ft-lb
Hawk 1
Aug 20, 2011 10:10 AM
stewartfan
2004 - 2008 F150
Sep 22, 2009 07:58 PM
webster
Oct 22, 2003 11:05 AM
