idle problem
Old Nov 23, 2010 | 02:52 PM
black bronco's Avatar
black bronco
idle problem
i got a 93 fullsize bronco with the 5.8 in it my problem is when i fire it up it idles around 1800 for about 15 sec which is fine then after that it lopes from around 1200 to 2000 and continually does that till i put it in gear and some times it stalls if im not quick on the gas. after running it down the road for a while then its fine.
anyone got any suggestions
Old Nov 23, 2010 | 04:54 PM
WINGNUT-'s Avatar
WINGNUT-
I'm trying to solve a similar problem with my '89. It can be caused by quite a few things. Does yours run fine when its totally warmed up?
Old Nov 23, 2010 | 05:23 PM
CWPottenger's Avatar
CWPottenger
Sounds like a bad or dirty IAC (idle air control) valve...
another possible issue is AC clutch... is it cycling on/off
Old Nov 23, 2010 | 05:38 PM
taisa899's Avatar
taisa899
vacuum leaks can cause all sorts of idle issues too
Old Nov 24, 2010 | 08:06 AM
black bronco
yeah it idles fine once its hot. thats what i was figuring was the iac all the vacuum lines look good but that doesnt mean a hole lot i gotta put a vacuum gauge on it
thanks for the advice guys
Jessie Castonguay
Bronco II
May 23, 2013 08:46 PM
nosebreaker
Mar 29, 2011 08:09 PM
wilevel2
Jul 7, 2009 04:24 PM
tom_strandberg
1997 - 2003 F150
Jan 31, 2008 05:26 PM
john crank
Bronco II
Jan 4, 2000 10:43 PM
