Stuck Ignition Key
Old Nov 22, 2010 | 10:28 PM
AGE's Avatar
AGE
Stuck Ignition Key
I pulled my 2006 Expy into the garage and shut it off today. The key wouldn't come out of the ignition socket. Started it up and tried again maybe 10 times. Tried force, jigglinng, etc--no luck. Then I noted that I had to move the vehicle in another 6" or so to close the door. Guess what!! Afterwards, the key came out.
What should I do if (when) it happens again? Any ideas?????
Old Nov 23, 2010 | 07:22 AM
alloro's Avatar
alloro
Maybe moving the shifter did the trick.
projectSHO89's Avatar
projectSHO89
Move the vehicle 6" in the future.
Old Nov 23, 2010 | 08:15 AM
sselvia's Avatar
sselvia
Silicon Spray!
Old Nov 23, 2010 | 08:19 AM
RedHorse1's Avatar
RedHorse1
I'm not sure silicone would be the stuff. I'd think graphite (powdered)
Old Nov 23, 2010 | 10:06 AM
Moto Mel's Avatar
Moto Mel
I have had Graphite gum up the tumblers in the past. I think I might try WD40 instead.
Old Nov 25, 2010 | 07:02 PM
1whoseeks's Avatar
1whoseeks
SEEN THIS BEFORE
Push the brake with your foot. Move the shifter fully into the park position. Sometimes this mechanism jams and will not allow the key to be removed.
Old Jan 29, 2014 | 10:43 PM
elkbison's Avatar
elkbison
The key can be taken out by disconnecting the negative cable on your battery. The reason why it got stuck is the bigger mystery.
Old Jan 30, 2014 | 06:57 AM
projectSHO89
That was a couple of years ago....
Old Jan 30, 2014 | 08:26 AM
r2millers's Avatar
r2millers
I agree with Red Horse, graphite is the right product. Ask your local locksmith, they don't use liquids, especially WD40. That's a solvent, not a lubricant.
There are silicone based sprays that I have used before but I always go back to dry lube.
Sometimes, moving the steering wheel back and forth slightly will help turn the ignition cylinder enough, helping to align the pins to remove the key.
banshee_man_96
Nov 22, 2018 07:20 AM
Spam46
Feb 18, 2017 11:51 AM
run6.0run
Jan 5, 2016 07:34 AM
parishboy
Dec 31, 2014 12:16 AM
bma2001
Sep 2, 2013 09:25 PM
