tourque converter
Old Nov 22, 2010 | 08:53 PM
gumper 123's Avatar
gumper 123
tourque converter
hello all been a while since i been on here ben very busy my 92 with auto started making nasty sound think it is tourque converter sounds bad when you let off it goes but when you excell off it sounds normal any thoughts i have not pulled inpection cover yet but i put tranny in 10 months ago.
Old Nov 22, 2010 | 09:25 PM
PLC7.3's Avatar
PLC7.3
Pull the lower inspection cover on the Bell housing.........
Check the 4 bolts for correct torque/tightness..... they can come loose.
Also check the flywheel..... they are known to crack around the crank bolt circle.... and it makes 1hell of a noise.
Old Nov 25, 2010 | 02:32 PM
gumper 123's Avatar
gumper 123
tourque converter
sure just pulled inspection cover 4 lose bolts i am so glad thought i was gona pull trany again
Old Nov 25, 2010 | 03:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
nice one PLC7.3
(as usual.)
gumper,
remember to flush that E40D every 30k normal/15k severe use,with filter change as well as least every other flush.
mwc3393
1978 - 1996 Big Bronco
17
Nov 23, 2013 12:29 PM
rma714
Jul 10, 2010 05:57 PM
David Smith
21
Jun 8, 2007 10:33 PM
llcustom
Jan 21, 2007 09:59 AM
DonL
Ford vs The Competition
Oct 23, 2003 08:49 PM
