Fuel pressure gauge
Old Nov 22, 2010 | 05:27 PM
King7765's Avatar
King7765
Fuel pressure gauge
Quick question for you guys before I do this.
I bought a 0-100psi liquid filled gauge and some fittings from my local hydraulic shop so I can hard mount a gauge where the shreader valve is.
Question is.... can I remove that shreader valve and install this without worry of getting air into the system? Also, I'm assuming that when the engine is off there won't be any pressure in the system right there, so I can pull it off safely?
Old Nov 22, 2010 | 05:36 PM
Ken_C's Avatar
Ken_C
I dont think you would get significant amount of air. it would quickly purge out if it did. if you push the schraeder core in and theres no pressure, should be ok.
Old Nov 22, 2010 | 05:41 PM
King7765's Avatar
King7765
Ok thanks. Thats tomorrows project.
Maybe a FPR shim after I see what it's reading.
Did the 10K mod and it did very little. Now I want to check the fuel pressure.
