1990 Bumper Removal
Old Nov 22, 2010 | 05:09 PM
Ford Tempo Fan's Avatar
Ford Tempo Fan
1990 Bumper Removal
So I slammed my '90 F-150 into a tree a couple weeks ago, and I've been working on tearing the front end apart and replacing parts and panels with ones from a '90 F-250 that I bought for $100. I've sorta run into a wall though, with the front bumper.
I can't get the damn bolts loosened at all. What I'm asking for is any techniques that ya'll members might have found helpful. I'd like to try everything before going to the blow torch for answers. I would also like to know if the F-250 bumper will bolt right on or if I'll have to do some custom fitting with the gas welder to make it work.
Input appreciated!
Old Nov 22, 2010 | 06:40 PM
cj06's Avatar
cj06
WD40 - liquid wrench or anything else like it and a deep well socket and breaker bar , impact wrench , piece of pipe on breaker bar !!
Old Nov 22, 2010 | 06:49 PM
Kapusta's Avatar
Kapusta
^^^ just what that poster suggested, plus try heat, but take care of your knuckles.
Old Nov 22, 2010 | 06:53 PM
cj06's Avatar
cj06
do the 2 bumpers look the same if so then they will bolt up
Old Nov 22, 2010 | 08:39 PM
Encho's Avatar
Encho
The Southernmost Mod
If you augment leverage you'll be applying a lot more torque to the nut, so go with what has been posted, find a pipe that fits in wichever manual tool you're using's handle and apply the torque, the nut should become loose. If the problem is that the nut is turning but it doesn't come out you have to stop the bolt... of course... good luck.
Old Nov 24, 2010 | 12:30 PM
Ford Tempo Fan
Thanks for the input. Its kinda hard to get a cheater bar into the small space between the bumper and the rest of the truck, but I've got a couple of ideas. I'm gonna heat that mother up and douse it in Aero-Kroil, than give it another try with the breaker bar.
Old Nov 24, 2010 | 01:44 PM
juni88126's Avatar
juni88126
yes the bumper will bolt up the f150 and 250 frame widths are the same
Old Nov 24, 2010 | 05:37 PM
eli85's Avatar
eli85
i would save the trouble and go buy the hardware and cut them off or grind the heads off and pound them out. If its anything like mine where youll break the bolt before it breaks loose anyways.
Old Nov 24, 2010 | 05:57 PM
Eddiec1564's Avatar
Eddiec1564
They are the same bumpers, I'm going to swap a 90 F150 on to my 89 F250. Just been soaking those nuts for a few weeks now before I try busting some nuckles....
Old Nov 25, 2010 | 09:54 AM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
i was sad, i opened this thread hoping to read about a severely lowered truck.... but yeah, liquid lubricant... my personal favorite is some stuff called "free" .... but free it aint!
61FordF-250
Apr 27, 2017 01:17 PM
houseofdiesel
Jun 26, 2016 05:52 PM
dan9812
Jan 30, 2013 10:35 AM
barryf
Mar 24, 2010 09:43 AM
