85 bronco parting out
Category: Engine - Complete Motors
Price: $450
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CL, TL & Vigor
Item Condition: IN
Engine: Part suitable for gas truck
I live in Vevay Indiana 10 mins from Madison.
85 Bronco mud truck. Flat black, lifted. The rear top has the sliding windows. Body is typical for old ford truck. Both doors were replaced (passenger side is damaged but still opens and closes). Tailgate has no visible rust.
351 crate motor around 80k miles with MSD ignition, edelbrock carb and headers ~ $450
I have a video of it running but it doesn't idle well, most likely the idle jet needs cleaned
C6 Automatic transmission (for 4WD) ~ $200
42"x15" r15 super swamper tires on 12" wide rims. 2 are in great shape, 1 is decent, the last tire is worn but still has the side lugs so it's still ok in the mud ~ $400
8" suspension lift with a 4" body lift (rear block, front new coil spring with drop A-arm brackets and drop pitman arm). I believe it's a sky jacker brand ~ $400
9" rear axle ~ $150
I'll let the whole thing go for $1350 (cheaper than parts). It's worth a lot more, but I have too many toys and don't feel like fixing it.
the XFer case doesn't shift into 4x4 and I broke the rear knuckle in the double cardon joint so it won't move on it's own. Also, the steering drag link is bent but I have a replacement to put on it. It's slightly toe'd in. Windshield is cracked. Has a very massive I-beam for a front bumper.
call 812-801-6172 or text or email ndawg@lavabit.com
If I had to guess, I say it may weigh 150lbs? If it comes out lighter, then I would refund the extra and only bill you the actual. If it goes over, I will eat the cost.
UPS says for 150 lbs the cost would run $130 bucks. Let me know if you're interested
