Clarks 4spd (3 w/ OD)
Ford RUG, RTS & SROD manual transmission illustrated parts drawings - Drivetrain.com
catalog here, takes a while to download:
MOTIVE GEAR - TRANSMISSIONS
Go ahead, waste your time and money with that POS. We warned you....
I would not be concerned about using one if it was in good condition to start with . Sure, if i was going to dump the clutch all the time or drag race, i would pass it up. I understand the shift pattern is different than a most 4/sp, but thats good . Less chance of somebody wanting to drive it , L.O.L. I just can't find one close by i can pick up to use.
same pattern as a regular 4 speed. just a dog leg style reverse is all. As for condition, mines just got a wine in 2 and 4th gear, and if you let out on the accelerator in 2nd it pops out. As for its use, its not going to get clutch dumped and drag racing, well its not going to see enough of it to be worried about.
I have never owned one ,the reverse must be what they meant when they said different . That would be no problem for me . I had a falcon with the ford factory floor shifter and it jumped out a lot allmost from day one and i bought it new, drove it 20 years . If i were in your place driving it the way i think you will , i would just drive it until it blows. Good luck. JIM
#29
They say the gears are cut different here, but you can't prove it from the pics:
Toploader Imposters
#30
A whine in 2nd and 4th, and it pops out of gear..... Rebuild kit might fix the whine if it's bearings, but probably not the popping out of gear. That might be shaft wear.
Toploader Imposters
Toploader Imposters
Home has an excellent reputation, especially from those that can't stand David's biased attitude.
Josh
