Tranny fluid capacity
Old Nov 21, 2010 | 05:14 PM
2006powerstroke90's Avatar
2006powerstroke90
How much transmission fluid does my 2006 hold?
I want to drop the pan change the filter and re fill.
Old Nov 21, 2010 | 05:42 PM
npccpartsman's Avatar
npccpartsman
No need to drop the pan and change the screen (it's not really a filter) unless you have a catastrophic transmission failure. Unless you're going to have the transmission flushed a good procedure is to drain the pan (about 8 or 9 quarts) drive for a few hundred miles and change it again. I usually change my auxillary filter (at the passenger front of the truck) on the second oil change.
Old Nov 21, 2010 | 05:57 PM
2006powerstroke90
Well I think my gasket is leaking. Would like to change it.
Does a napa sell the aux filter?
Old Nov 21, 2010 | 06:05 PM
69cj's Avatar
69cj
Buy Motorcraft or NTZ the manf. for motorcraft. Cheaper at dieselfiltersonline if your in no hurry.
Old Nov 21, 2010 | 06:08 PM
2006powerstroke90
What's that the aux filter?
I wanted to get royal purple ATF.
Old Nov 21, 2010 | 06:13 PM
69cj's Avatar
69cj
It's the filter behind the front bumper.
Old Nov 21, 2010 | 06:15 PM
2006powerstroke90
The one that looks like it's going to the radiator?
But napa should sell it?
Old Nov 21, 2010 | 06:19 PM
69cj's Avatar
69cj
Buyer be ware!!
Old Nov 21, 2010 | 06:22 PM
2006powerstroke90
But is that the one? Napa no good?
Old Nov 21, 2010 | 07:57 PM
2006powerstroke90
I did find it. I just want to verify I do the right thing.
Get a "Motocraft" filter.
I unscrew the filter "housing"
And the old filter should be inside?
Old Nov 21, 2010 | 08:12 PM
wulfman's Avatar
wulfman
Yes the old filter is inside, its looks likes a roll of toilet paper. One more use only MERCON SP trans fluid,anything else could cause problems, good luck
Old Nov 21, 2010 | 08:17 PM
2006powerstroke90
Sounds simple enough.
Going to do it friday if it's nice enough out.
I'm going to take the pan off, change the filter, gasket(since it's dripping from the pan) do the aux filter and refill it and see how it is. In a few hundred I will drain it again and change the fluid
Old Nov 21, 2010 | 08:24 PM
ljutic ss's Avatar
ljutic ss
Mercon LV is also recommended along with Mercon SP
Old Nov 21, 2010 | 08:30 PM
wulfman's Avatar
wulfman
Hey the pan has a kind of O ring type gasket that is reuseable, I pulled my pan the first time and changed screen slash pickup, cause didnt know better, so thats why it seeps just a hair now, dont over tighten the bolts
Marioj87
2004 - 2008 F150
Jan 28, 2016 05:19 PM
Jmroach
May 14, 2014 08:45 AM
Rick2006
Mar 28, 2012 01:24 PM
2006powerstroke90
Jun 10, 2011 09:13 AM
chuckstruck06
Aug 12, 2008 09:47 AM
