Cluster swap
Old Nov 21, 2010 | 07:05 AM
73' f-100's Avatar
73' f-100
Cluster swap
I have a cluster with full gauges and the metal backing has a broken wire on it, I recently got a cluster from a 78' F-250 that I like better because it is gray instead of black around the gauges, The major difference is that mine has full gauges and this one has dummy lights on it. I am wondering if the two clusters will swap out? I was also wondering what the cons are of the dummy lights if any? I have an aftermarket temp gauge and am planning on installing more gauges in the future because I like the more accurate reading.
Old Nov 21, 2010 | 07:13 AM
bucks77ford's Avatar
bucks77ford
The clusters won't swap out. If your truck has gauges than you need one for gauges.
Old Nov 21, 2010 | 07:20 AM
73' f-100's Avatar
73' f-100
Thats what I was thinking thanks for the reply.
Old Nov 21, 2010 | 11:45 AM
steponit's Avatar
steponit
Warning light clusters have 14 pins on the connector
Gauge clusters have an 18 pin connector
Physically impossible to swap never mind the wiring harness differences
