f450 diffrential
Old Nov 20, 2010 | 08:53 PM
therigwelder's Avatar
therigwelder
f450 diffrential
what rearend does my 1996 450 have?right now its geared low, granny gear.i want something better suited for highway and mpg.what can i use?
Old Nov 21, 2010 | 04:05 AM
Lazy K's Avatar
Lazy K
Ford Axle Code Chart .: Articles Match your door sticker axle code to this chart. Ignore where it says 1991.
Old Nov 21, 2010 | 08:24 AM
therigwelder
original sticker not there truck has a diffrent cab off a 150 i was in a bad accident was a rebuildable wreck
Old Nov 21, 2010 | 11:13 AM
Ford_Six's Avatar
Ford_Six
There should be a tag on the axle with the ratio, then.
It'll be either a Sterling 10.5 or a Dana 70, maybe a Dana 80 if it was an ambulance.
Old Nov 21, 2010 | 03:50 PM
therigwelder
no tag on axle someone must have opened the cover before i got it.the other truck i had was a 92 f350 it had a 10.25
Old Nov 21, 2010 | 05:01 PM
Ford_Six's Avatar
Ford_Six
Post some pics, and someone will be able to identify it. You may have to open it up to find the gear ratio.
Old Dec 3, 2010 | 06:55 PM
rebuildman's Avatar
rebuildman
F450's of that era came with a Dana 80. More than likely it has either 4.63 or 4.88 gears in it. You can go to a 3.73 ratio and still use the same carrier you have now. I wouldn't go witha faster ratio than that anyhow because of the weight of the truck.
Old Dec 18, 2010 | 12:59 AM
superdutytt's Avatar
superdutytt
rebuildman ive got an 08 450 with 4.88 can i put a 3.73 in it and where would i get them?
