bleading a slave silinder??
Old Nov 20, 2010 | 08:37 PM
jg96powerstroker's Avatar
jg96powerstroker
hey guys tranny swap is done!!! i gotta fix a few wires and and a down pipe prob, but no biggy, my prob is what is the best way to blead a slave silinder?? myn has a allen screw on bottom and tryed pumping up and cracking allen head, seamed like we got no where! thanks guys
Old Nov 20, 2010 | 09:38 PM
quesey's Avatar
quesey
on some others i've found it works better to just open the bleeder and let it drain with the cap off.and keep the top full
Old Nov 20, 2010 | 10:08 PM
jg96powerstroker
how long dos that take when you do it that way?? i pumped and pumped they crakeed bleader than pumped! dude the 165 for a bench blead set up seams good about now!! lol did you just crack the bleeder so it just drips or open it and it run a steady stream?
Old Nov 21, 2010 | 09:13 AM
quesey's Avatar
quesey
i just opened it up and let it bleed till i thought it drained all the air out.had a dirt car that we tryed bleeding it for over an hour and still nothing so we just left it open and then it worked
Old Nov 21, 2010 | 09:39 AM
MagKarl's Avatar
MagKarl
Leave the slave hanging by the line. Pump the slave by hand carefully and slowly to force the air up the line and into the master reservior. Gently pump it till you feel the fluid resistance, then attach the slave. I had to use a bar clamp to compress mine to install. Somebody here had a better idea and pulled the actuator arm with a ratchet strap.
brightideaselectric
6.7L Power Stroke Diesel
16
Jun 5, 2015 09:49 AM
Gword256
Jan 26, 2010 04:27 PM
1wicked90lx
Jan 25, 2010 09:14 PM
glenn65
1983 - 2012 Ranger & B-Series
16
Dec 31, 2005 12:16 AM
Spooky
Aug 18, 2004 08:16 AM
