did you make sure the headlight switch is turned all the way to make sure it's not dimming the dash? it has happened before where people forget about that.
Have you checked to make sure you have power at the plug? If you have power at the plug than it's a cluster problem. In many cases it's the printed circuit that goes bad.
I have an aftermarket harness, but I think the Light Blue/Red Stripe wire is for the dash lighting. If power is there, than I'd try getting another cluster and see what happens.
I also have experienced the headlight switch has corrosion on it so the contacts are bad causing loss of power to the dash, but usually the dome light doesn't work either.
I'd also try swapping out the lighting sockets on the cluster for other ones to see if they work. Corrosion can build up on the printed circuit and the sockets don't make a nice contact and if it looks like there is some white powder on the copper lighting circuits you can take a pencil eraser and clean them.
