need some help
Old Nov 22, 2010 | 09:18 PM
dimambro2's Avatar
dimambro2
ok made a new jumper wire from the alternator to the passange side battery get the batteries to read 14.2v i figure the other .4v is due to accessories running like fuel pump and guage cluster, pcm, and ecu. heres the thing the stupid light is still on....driving me nuts
Old Nov 23, 2010 | 01:57 PM
Jbrown8988's Avatar
Jbrown8988
same boat i am in. just signing up to find out what you come up with
Old Nov 23, 2010 | 02:11 PM
Nick 99's Avatar
Nick 99
Correct me if I am wrong, but it seems to me that if you disconnect the small connector at the alternator and the lamp goes out, you have found the problem, If on the other hand if when you disconnect the small connector and the light stays on, them you have a wiring problem.
Old Nov 23, 2010 | 03:16 PM
dimambro2's Avatar
dimambro2
no if i disconnect the connector on the alternator it will stop producing voltage tocharge the system i just thought that maybe the loose connection might be the problem.
still looking for a way to make that connector secure since they broke that clip
Old Nov 23, 2010 | 03:57 PM
Nick 99's Avatar
Nick 99
if you suspect a bad/ loose connector, you might get a replacement from Ed the parts guy on this forum, or go to your local alternator re-builder in your area.
Old Nov 24, 2010 | 04:57 PM
dimambro2's Avatar
dimambro2
still looking, if i throttle it hard it kicks off.......doesnt solve anything just makes me wonder more now!
Old Nov 24, 2010 | 05:41 PM
strokingbeast's Avatar
strokingbeast
Its something I have been dealing with for over a year now
Old Nov 24, 2010 | 05:45 PM
just another truck's Avatar
just another truck
Originally Posted by dimambro2
the only reason that i dont think its the alternator is the fact that i will put out 14.6v which seams right but the batteries will not charge to 14.6v only 14v. does anyone now wha the light on the dash is trigger by?
thanks
The plug on the back of the alt, if loose will cause this light to go. Please know aI have not read all of the other post, but NORMALLY, if the light is coming on, it will be the alt. It may be putting out 14 volts, but it may not be a clean DC signal, causing damage to the battery. Good LUck!!
Old Nov 24, 2010 | 05:48 PM
clintbonnie's Avatar
clintbonnie
My light was coming on intermittely and it was one of the small wires shorting out to the alternator housing.. not the alternator..
scooterspal
1983 - 2012 Ranger & B-Series
Jul 18, 2014 03:17 PM
97ranger xlt
Dec 28, 2012 06:59 AM
allegedgenius
Jun 5, 2011 02:21 PM
stumpy_1958
May 5, 2011 10:18 AM
slaviers
Oct 23, 2008 08:19 AM
