Door Latching Mechanism - Temp Fix?
Old Nov 20, 2010 | 05:37 PM
mq1shooter's Avatar
mq1shooter
My 95" door's other than the hinge play and they need to be worked, I noticed that the latch mechanism " plastic Bush"? was worn, cracked.....so I took some 1/2" very hard woven plastic tubing called "Beverage Flex" and split it down the middle, wrapped just nicely to the metal shaft and well it's working! Kinda tighten that end of the door quite well...cheap fix, just wanted to pass it on...
http://i1091.photobucket.com/albums/...Picture011.jpg
Old Nov 20, 2010 | 05:51 PM
Action4478's Avatar
Action4478
Fix the pins & bushings next
Old Nov 20, 2010 | 05:52 PM
95_Dually's Avatar
95_Dually
X2 what he said. It will be like new after you do this.
Old Nov 20, 2010 | 05:54 PM
mq1shooter's Avatar
mq1shooter
Willl do...I saw a good thread here somewhere and they were not hard on the wallet...my kinda repair...
Old Nov 20, 2010 | 06:43 PM
RRranch's Avatar
RRranch
You can buy those plastic sleeves real cheap in the help section at just about any parts store too. And the hinge pins and bushings. I used to use a dogde pin and bushing set on fords that were really wallered out. They are bigger.
