91F350 no trailer lights
Old Nov 19, 2010 | 04:54 PM
BLUE62's Avatar
BLUE62
Just got it home today 91 F350 1ton duel 460 C6 crew cab 8ft beb looks to have factory harness found the lovely fuse links by the start relay and the one for the clearance lights had blown it had been shorted to ground at the link so i jumped it to check the lights and they work so witch one is for the trailer harness?
Old Nov 19, 2010 | 05:38 PM
danr1's Avatar
danr1
Its the same circuit but there is another fuse link after the marker lights, well diagram I have suggests that, but I don't know where its located.
At the starter rely its a black fuse link (think you probably know that now), then a yellow wire to a second brown fuse link then a black-white wire from there to the trailer light/marker lights relay (dual wheels).
I'd follow the black-white wire back from the trailer light relay until I found the fuse link, unless someone else knows where it is.
Edit;
Not intended to suggest one relay, might be though, do the markers on your rear fenders work? Does have markers on em right?
Old Nov 20, 2010 | 09:50 AM
BLUE62's Avatar
BLUE62
Hey danr1 good info good web site hookup yes it has the fender lights and I got it repaired this mornning and all is well thanks much now to get the 75f250 crewCab hooked up behind it and start the road trip from Phoenix to Iowa
Old Nov 20, 2010 | 09:54 AM
BLUE62's Avatar
BLUE62
Oh yeh Im new to Fords and this thing you call the internet so please let me know if or when Im not getting this right as as far as posting or replying thanks again.
cnelson
Oct 21, 2013 04:35 PM
fireeater91
Jul 20, 2012 09:39 PM
jeepmonkeymark91
Sep 26, 2011 11:11 AM
Nightrain
All Things Towing
Feb 3, 2008 11:41 AM
tobyw
Oct 16, 2001 12:07 PM
