Even if they're not, you probably wouldn't have to make any extreme modifications- maybe change out the light sockets- but the primary wiring should be the same.
88. the 87 uses a flat truck side plug and the 88 has a round truck side plug. i think. one or the other. i do know this though because in the spring when i went to pick up the 87 bed to put on the 88 i did not bring the 88 rear wires thinking they were the same.
so i had to drive home with the magnet mount trailer lights.
that was when i also found out about the bulbs, and had to repair the fubared 88 harness.
My 1988 diesel donor truck has considerably different harnesses throughout the truck than my 1991 does. The wires are mostly the same but the plugs are not.
I need the whole rear harness. From where it plugs into the main harness that comes from the front. I need it for a 91 F350. Would like to find NOS if possible.
