Transfer Case
Old Nov 19, 2010 | 11:29 AM
scotty088's Avatar
scotty088
Transfer Case
According to the Ford Build your own website there is no options for anything other than the shift on the fly transfer case. Is this the case? I guess I'm old school in the fact I like to feel the positiveness of pulling the shifter in manually to be assured of full engagement. My 2007 has the manual t-case and that would be my preferance. As usual Thanks for the feedback.... Scotty
Old Nov 19, 2010 | 11:44 AM
Byram's Avatar
Byram
If you order the XLT 4x4 it comes with manual & you can upgrade (dowgrade?) to ESOF... I think Lariat package includes it..
Old Nov 19, 2010 | 12:52 PM
Marauder92V's Avatar
Marauder92V
The XL and XLT come standard with manual locking hubs and the manual shifter. Byram is correct that you can buy the ESOF and auto/manual locking hubs as an upgrade on the XLT line. I like the fact that they allow you to manually lock the hubs in case of auto hub failure. As well, I like the ELD capability. IMHO, much better than limited slip.
Old Nov 19, 2010 | 02:07 PM
tampacamper's Avatar
tampacamper
Question, With the ESOF can you put the truck in neutral? My Parents have a Phaton coach and would like to flat tow the truck behind it.
Old Nov 19, 2010 | 02:08 PM
Big Ruth's Avatar
Big Ruth
I didn't know you could get the manual T-Case in the XLT. Man I wish I had that.
They had a totally stripped down XL on the lot with manual T-Case.
I wonder if it would be hard to change my electronic to a manual.
Old Nov 19, 2010 | 02:09 PM
Byram's Avatar
Byram
I don't think so...
Old Nov 19, 2010 | 03:57 PM
BTyner41's Avatar
BTyner41
No neutral position on the ESOF
Old Nov 19, 2010 | 03:58 PM
Marauder92V
I don't think so either. You can do it with Jeeps including the QuadraTrac ones. Tell them to get a Wrangler for running around town
Old Nov 20, 2010 | 07:02 AM
tampacamper
Thanks, it was for me. When I borrow the coach
Old Nov 20, 2010 | 07:54 AM
ruschejj's Avatar
ruschejj
When I greased the yokes on my '08 it took all of 10 minutes to remove the main drive shaft. I would think that doing so would be the best way to pull your truck behind that Phaeton. I didn't have to remove the whole shaft but it was very easy to do the front joint so I am sure that the rear joint at the diff would also be very easy.
whiskeyrichard
Mar 5, 2022 10:34 AM
Scotty76
Mar 31, 2013 02:32 PM
mj_355
Feb 28, 2013 04:40 AM
for46016
1978 - 1996 Big Bronco
Feb 11, 2009 10:58 PM
bIIcool
Bronco II
Nov 8, 2008 03:55 PM
