oil leak
Old Nov 19, 2010 | 10:33 AM
parkers5150's Avatar
parkers5150
oil leak
first of all Thanks Lazy K for helping me with the tranny. while i was under there i noticed oil leaking down the exhaust manifold. I'm new, i have an 89 E-350 van (just purchased) haven't exposed the motor. this oil leak seems to be in an odd place??? remember i'm a newbie
Old Nov 19, 2010 | 10:43 AM
ExtrmZ's Avatar
ExtrmZ
could possibly be coming from the valve cover, then running down onto the manifold. Thats what mine does anyway. Im too lazy to put new gaskets in there.
Old Nov 19, 2010 | 10:44 AM
Old93junk's Avatar
Old93junk
Valve cover gasket..........common problem. Which side?
Old Nov 19, 2010 | 10:51 AM
wycowboy63's Avatar
wycowboy63
Me too, lol. I just put up with it.
Chris
Old Nov 19, 2010 | 10:56 AM
Old93junk's Avatar
Old93junk
Chris
You guys are OK with the little old ladies who point and say, "Sir! your truck is smoking!, its not on fire is it?"
Old Nov 19, 2010 | 11:00 AM
ExtrmZ's Avatar
ExtrmZ
well you have to be.. just open the hood and pour another quart in there.
Old Nov 19, 2010 | 11:04 AM
parkers5150
thanks for the replies. its the drivers side. its a van are the gaskets a pain in the **** to replace??
Old Nov 19, 2010 | 11:08 AM
Old93junk's Avatar
Old93junk
Ahh! breathe deep!, love that smell of burning oil on the exhaust!
Valve covers are a PITA on EFI small blocks, have to remove upper intake for pass. side. Budget a few hours on a Sat. for this job.
Old Nov 19, 2010 | 11:10 AM
Old93junk's Avatar
Old93junk
Drivers side not too bad on F-series, van.....unsure.
Old Nov 19, 2010 | 11:11 AM
parkers5150
its a 7.5 460
Old Nov 19, 2010 | 11:16 AM
Old93junk's Avatar
Old93junk
its a 7.5 460
Well that changes the game. Yes, its going to be a pain, I have worked on Class C motorhomes(1 ton van chassis) with the 460. tight working space to be sure. You will be doing most of the work from the doghouse side in the van.
Old Nov 19, 2010 | 11:21 AM
parkers5150
that being said the fella that i just purchased the van from said that there are two manifold bolts that are snapped off (issue for smog inspect.) I guess i need to go buy some beer and get busy. do any of you have some advise for me as far as replacing the snapped head bolts? Also while I'll be in this area what else should i adress. when i get this thing on the road i want to be confident
Old Nov 19, 2010 | 11:27 AM
Old93junk's Avatar
Old93junk
Manifold? intake?...exhaust?
Top off on patience and band aids before starting.
parkers5150
also, would it benifit me to pull the seats before i start? ( don't hate me cuz it's a van)
Old Nov 19, 2010 | 11:31 AM
parkers5150
the previous owner did not specify intake or exhaust won't know til i go
