Need help on flathead engine swap
Old Nov 19, 2010 | 10:13 AM
harleymsn's Avatar
harleymsn
OK, this is not a ford truck, BUT .....
Here is the deal, a buddy of mine has a 46 Merc Coupe that does not have an engine. We have been looking to install an 8BA into it but he has some real concerns. The car still has the original transmission (minus the clutch) as well as the enclosed driveshaft. It does not appear that the bellhousing from the 8ba will line up and he is concerned about major modifications if we swap out the transmission. The motor mounts are also missing from the car and it appears that the mounts on the 8ba will need to be modified, but that seems minor.
Anybody have any experience or advice with such a swap?
Old Nov 19, 2010 | 10:24 AM
havi's Avatar
havi
I'll have the Roast Duck
The water pumps with the motor mounts built in to them are different between trucks and cars. My F1 came with Merc water pumps and oil pan, and the PO had installed mount risers to make it sit right in the F1. Hard to do the opposite in lowering an engine, though. So the question is, what water pumps are on the 8BA going in?
Old Nov 19, 2010 | 10:32 AM
mtflat's Avatar
mtflat
Joe, you're going to need more detailed info than we can give you here. You're dealing with waterpump and bellhousing issues as well as early vs late flathead details. What you want is pretty straight forward.
Check into this link - these guys can walk you thru the swap and they have a complete guide to bellhousings and a tech page that has tons of helpful info.
Ford Flathead V8 .. 1932 thru 1953 • Index page
Old Nov 19, 2010 | 11:06 AM
harleymsn's Avatar
harleymsn
I have both car and truck water pumps available, I have an 8ba from a '50 car, but it needs work, I also have an 8ba available from a '49 F6.
Old Nov 19, 2010 | 11:08 AM
harleymsn's Avatar
harleymsn
Yep, I know there is more info over there. I registered a few days ago and am still waiting for them to activate me to post there.
I have been told that the bellhousing from a late pick up will work, but I need to know if the bellhousing from an F6 is the same.
Old Nov 19, 2010 | 12:48 PM
4tl8ford's Avatar
4tl8ford
The Merc water pumps/mounts are different - the engine mount bolts are 1 inch higher and 1/2 inch closer or further apart than a ford
I have a 46 Ford Coupe that had a Merc Flatmotor in it and it had a "U" shape (on it's side) adaptor for the mounts
Old Nov 19, 2010 | 01:16 PM
312's Avatar
312
as was said you use a truck bell from 49 to i think 52.its just an extension to make it match early flathead trans.
Old Nov 19, 2010 | 01:18 PM
mtflat's Avatar
mtflat
Sorry for the delay, I'll tell Bill to hurry and activate you. edit: looks like you're in - welcome to flathead central!
Yes the truck half-bell from the F6 will work. It's cast where the merc is pressed steel, but bolts the same to the best of my knowledge.
Here's the link to the bellhousing pdf file
http://www.flatheadv8.org/bellhousing.pdf
50trucking
24
May 27, 2025 02:00 PM
farmall_7
15
May 8, 2016 06:12 PM
Todd15
24
Dec 28, 2015 03:06 PM
I_Am_Ozymandias
Engine Swaps
May 16, 2015 11:13 PM
j_siegel
Dec 4, 2014 10:04 AM
