Sponsored by: Real Truck
Long Box Compatibility
Old Nov 19, 2010 | 01:41 AM
MN_Viking's Avatar
MN_Viking
I can't remember what years can be swapped for the boxes. I need a new long box, can I look up to a 06?
p.s. i used the search button and the googles
Old Nov 19, 2010 | 11:56 PM
FI460's Avatar
FI460
Give ya a bump here. I'm not 100% on this but I believe they're all the same up until 2007. I think the 2008+ fit but the lines are different...
Old Nov 20, 2010 | 12:17 AM
rollerstud98's Avatar
rollerstud98
Difference is in the wheel arches I do believe, but even the 2011 boxes will bolt up, but again the wheel arches are different from the 08-10
Old Nov 20, 2010 | 12:34 AM
brian42's Avatar
brian42
Veteran: Navy
I know that the '99-'04 were the same box. Past that I do know that the tailgates are swappable up to '10.
Old Nov 20, 2010 | 01:20 AM
MN_Viking's Avatar
MN_Viking
Thanks guys! I think if I look for up to 04 I should be OK on finding one. I may go to the local body shop and ask if they can find me some.
Old Nov 20, 2010 | 10:41 AM
galaxie641's Avatar
galaxie641
I think it is a member of this site that put a '10 box on a '99 or something like that, looked really good. As long as you don't want to use your stock tailgate I think you can go all the way to new. Also F150 boxes and gates will work '97-'03.
Old Nov 20, 2010 | 04:16 PM
2002 F350V10's Avatar
2002 F350V10
I have put 2 2011 superduty take off boxes on older superdutys which I own. One is a 99 the other is a 2000. They bolt right up to the frame the same, but wiring needs to be worked over a little to work. Bumpers are also a direct bolt on.
For the fuel filler tube, you need 3 self tapping screws to make it work. For the wiring with the newer tail lights, the simple way is to use your old tail light harness and splice the newer pigtails on for the reverse lights. For the bumper you need to drill a small hole left of the license plate for access to remove the spare tire. Simple Enough????
I found the boxes in the correct colors I needed and atleast the white and red colors are the same as the older trucks. The wheel well arch is slightly different but not even noticable when mounted on the truck. If you have a plastic bed liner , it fits the same as well. For pics you might search my old posts. New bed= new metal, new paint, no wear, perfect condition. Can not get much better than that.
Old Nov 20, 2010 | 06:25 PM
rollerstud98
Tailgates are interchangeable from the F150 97 to 03, but the boxes are different.
Old Nov 26, 2010 | 10:24 PM
MN_Viking's Avatar
MN_Viking
Holy crap thats swesome guys!! thanks for the info!
Riggin
Sep 5, 2013 04:07 PM
81F100C
Jul 19, 2012 08:02 AM
black water
18
Sep 12, 2010 12:23 AM
blue 79
Alberta Chapter
May 6, 2003 11:34 PM
MichaelG
Apr 14, 2002 09:17 PM
