Sponsored by: Real Truck
Strange front end noise
Old Nov 18, 2010 | 10:55 PM
bakerbuilttracks's Avatar
bakerbuilttracks
I got a Late 99 7.3 psd 4x4 This has been going on for awhile now and i got to get it fixed whatever it is.
I will try to explain my issue the best i can so here it goes.
Going down my dirt road going 10 mph never faster than 15 when i go over small to large bumps i get a grinding noise in the front end that i can kinda feel in the steering wheel. Almost sounds like its coming from the gear box or P/S pump. My foot is off the gas when i hut the bumps and it makes the noise. If i accelrate when i hit the bumps the noise gets a bit worse. I get the same noise in two diffrent areas other than the dirt road hitting bumps.
One of them is while towing ..... If im towing and come up to a stop light as soon as i stop not moving at all the noise starts.... If i turn the wheel left or right the noises gets worse. If i hold down the brake and acclerate it goes away.
Seccond one is while my truck is lugging. Example.... Running 45mph in o/d start climbing a hill truck slows to 40 or 42 dose not down shift stays in o/d running 1100 to 1300 rpm i get the same noise.
This is compleatly mind boggeling to me. I replaced the P/S pump last year. I really cant figure this out. I got a few things i can think of
1. Hydroboost system
2. Steering Gear Box.
3. Bad pully somewhere
4. Bad Belt Tensioner / Pully
I dont know how to tell if the above are bad I have never had a problem with any of them so maby one of these is bad and i just dont know.
I would really appericate all the help i can get on this one. I just have no clue at this point. Sorry for writing a book.
Thanks FTE <!-- / message -->
Old Nov 19, 2010 | 01:17 PM
jblksmith1's Avatar
jblksmith1
Can you feel it under your feet in the passenger seat or through your accelerator pedal? Just curious. That's where I "feel" my noise.
Old Nov 19, 2010 | 01:58 PM
Future_LEO's Avatar
Future_LEO
Sounds like you're having what I'm having, and I'm leaning towards sway bar bushings.
No idea about the OP problem though...
Old Nov 19, 2010 | 02:36 PM
jblksmith1's Avatar
jblksmith1
Replaced all that already.
Old Nov 20, 2010 | 07:49 PM
bakerbuilttracks
i mainly feel it in the wheel and the floor board. Its not a bushing or ball joint or anything related i that manner. The noise comes and goes almost with the rpm. Mainly arround 1100 to 1350 rpm when the truck is in od lugging up a hill. Or like i explained in my first post
Old Nov 22, 2010 | 09:58 PM
dqdave1's Avatar
dqdave1
check idler pulley
Scirok
Jan 13, 2012 11:05 AM
snoopt1
Jul 2, 2011 01:50 AM
bakerbuilttracks
Sep 17, 2008 08:01 PM
timmyp
Dec 5, 2005 09:52 PM
gstanfield
Oct 8, 2003 03:55 AM
