no start when cold
Old Nov 18, 2010 | 09:03 PM
yegalex's Avatar
yegalex
no start when cold
04 f350 SD 6.0
hard or no start when cold, if its plugged in over nite starts right up ? checked glow plugs and module getting right amps. replaced injector. could the egr valve couse the hard start condition? no codes.
Old Nov 18, 2010 | 09:10 PM
bismic's Avatar
bismic
Where is your ICP sensor - passenger valve cover or behind/under the turbo?
Old Nov 18, 2010 | 09:33 PM
yegalex's Avatar
yegalex
behind turbo looks like the connector has been changed shrink rap around wires
Old Nov 18, 2010 | 09:40 PM
bismic's Avatar
bismic
The EGR valve could cause a hard start, but you should see a lot of black smoke with it. It is more likely to be the FICM, injectors, or a HPO (high pressure oil) issue (leak or pump).
There is a no-start troubleshooting thread near the top of the list in the Tech Folder.
