1997 Powerstroke Issues Please Help!
Old Nov 25, 2010 | 07:21 PM
Timmy2Stage's Avatar
Timmy2Stage
Should I pull the IPR sensor and check the o-ring?
I've disconnected the sensor and all it did was cause the tranny to shift harder.
Old Nov 25, 2010 | 07:27 PM
Timmy2Stage
At operating temperature and at 2500rpm and higher the problem is not there.
Old Nov 25, 2010 | 07:38 PM
mq1shooter's Avatar
mq1shooter
I would trust and belief what Action4478 say's and check the IPR o-ring...Troubleshooting takes time and a process of elimination....believe me.
Last edited by mq1shooter; Nov 25, 2010 at 07:39 PM. Reason: Misspelled "Believe" OHH too much turkey!
Old Nov 25, 2010 | 07:42 PM
mq1shooter's Avatar
mq1shooter
Crankcase is at the full mark. I've tried unplugging the IPR and all it did was throw a check engine light and shift harder.
I will double check in the morning to see if I'm 100% sure the problem doesn't exsist when it's cold. Maybe it does and it's just not as pronounced.
One time it was really bad and it was effecting the shift firmness, only happened once though.
...You unpluged the IPR? or the ICP?
Old Nov 25, 2010 | 08:01 PM
fordpride's Avatar
fordpride
I would go ahead and change the oil and see what happens
Old Nov 25, 2010 | 08:51 PM
Timmy2Stage
I unplugged the sensor on the front of the driver's side head. I believe is the IPR sensor.
Old Nov 25, 2010 | 08:57 PM
fordpride's Avatar
fordpride
That the ICP
Old Nov 25, 2010 | 09:00 PM
fordpride's Avatar
fordpride
This is the IPR
Old Nov 25, 2010 | 09:46 PM
Timmy2Stage
Should I try unplugging the IPR to see if the problem goes away?
Old Nov 25, 2010 | 09:49 PM
fordpride's Avatar
fordpride
if you unplug the IPR it will not run it controls the oil pressure to the injectors
Old Nov 25, 2010 | 10:39 PM
Timmy2Stage
I will check the IPR o-ring first, then I will change the oil if that shows no problem.
fordpride
15
May 23, 2016 01:00 PM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
fordpride
Jun 26, 2012 10:49 PM
6OH
May 6, 2010 02:22 PM
