Plastic behind door panels
Old Nov 17, 2010 | 09:03 PM
Fish_Scientist's Avatar
Fish_Scientist
What's the point? Moisture barrier? Dust "barrier? I pulled the panels off of Patience last weekend and saw some (likely) aftermarket plastic. (It was pink.) Needless to say, it was in bad shape and almost non-existent. What's the best material with which to replace the original? Vis-queen? A garbage bag?
Old Nov 17, 2010 | 10:50 PM
TexasTrash's Avatar
TexasTrash
I'm pretty sure a PO put that their, I have no clue why. I did have a 05 vehicle that had a bunch of plastic under the door panel, I had to pull it all off to work in there.
Old Nov 17, 2010 | 11:00 PM
piperig78's Avatar
piperig78
You can use any plastic drop cloth sheets, or insulation covering. I try to find the thickest possible. I have noticed the the cab gets and stays warmer in the winter with the plastic in place. Most vehicals have them originally.
Old Nov 17, 2010 | 11:02 PM
piperig78's Avatar
piperig78
but that looks like someone was trying to keep water off that speaker. Hows the weather stripping for the windows?
Old Nov 17, 2010 | 11:07 PM
compressorguy's Avatar
compressorguy
The original was a heavy petroleum impregnated kraft paper. I have used 6 mil visqueen before. On my 78 I covered the whole area with dynamat. It made a huge difference in the noise and moisture coming through the panel. If I need into the door I will just cut out the hole and recover it when I am done
Old Nov 17, 2010 | 11:10 PM
USArmyTaterness's Avatar
USArmyTaterness
Normally called a moisture barrier used for what it sounds like. Keep water outa the open parts of your door. Doesn't matter much when the window stripping has craked and lets water through though.
Old Nov 18, 2010 | 10:26 AM
MAULMAUL's Avatar
MAULMAUL
You can buy speaker "shields" from crutchfield. They are pretty cheap and designed to keep water from dripping on the speakers from the window seal.
Old Nov 18, 2010 | 12:40 PM
HIO Silver's Avatar
HIO Silver
They're called water shields. I have successfully used wax paper as a substitute. Works great.
With regards to the speaker shields (sometimes called baffles), you can get them aftermarket but most new door speakers come with a pair.
Old Nov 18, 2010 | 12:54 PM
steponit's Avatar
steponit
One can also use shipping wrapping paper and duct tape
The sound from those speakers must have been horrible.
NashvegasMatt
Aug 25, 2016 11:58 PM
Airslot
Sep 2, 2013 08:49 AM
VegiePower
Dec 14, 2011 11:09 AM
fatherdano
Jun 3, 2011 11:31 AM
montanafordman
1997 - 2003 F150
May 8, 2008 02:52 PM
