GPR LED QUESTION ?????
Old Nov 17, 2010 | 07:48 AM
wuttrd's Avatar
wuttrd
gpr only comes on after i fire the motor. isent it suposto come when the key is in the on postion ??? when i first instaled it last wenter could have swarn it came on with key in on. truck starts fine in the morning just cant rember thanks for the help.
Old Nov 17, 2010 | 08:01 AM
DND58's Avatar
DND58
It should come on when key is first turned to on position. Not sure how cold in AZ now. Does the light turn off later? You may want to check things with a meter.
Old Nov 17, 2010 | 08:03 AM
wuttrd's Avatar
wuttrd
meter
yes the light goes out like normal. it is not that cold yet 50 this morning. how and where do i check the relay. thanks for the responce.
Old Nov 17, 2010 | 08:19 AM
DND58's Avatar
DND58
Only one side of the relay is hot from the battery all the time. When you turm the key, the relay should close and the other side becomes hot to the glow plugs. This is the side I tied my GPR LED to.
Old Nov 17, 2010 | 09:42 AM
wuttrd's Avatar
wuttrd
volt
so i should get voltage when i turn the key to the on postion.?? what would it mean if i only get voltage to plugs when the motor fires??
Old Nov 17, 2010 | 01:36 PM
DND58's Avatar
DND58
Yes, you should get voltage to the second large terminal of the GPR when key on. I do not know why you only get voltage after motor fires. I do know the PCM sends a ground to one of the small terminals on the coil for the GPR. Oil temp, outside air temp, a number of things are factored into the PCM sending the ground.
Bump
Old Nov 17, 2010 | 01:44 PM
Ponyboychris's Avatar
Ponyboychris
Yes, the GPR gets power to the plugs when you turn your key to the on position. Double check the GPR with a test light to see if your LED is corresponding to the lug on the relay.
Old Nov 17, 2010 | 03:27 PM
wuttrd's Avatar
wuttrd
gpr
i will have to check it with a test light when i get home from work. if the test light corresponds with led could it be a bad relay, or is it a pcm ground issue sooo confused. thanks for the help.
